Driver side tail light dimmer than passenger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rougarou680, Sep 18, 2024.
  1. Sep 18, 2024 at 5:13 AM
    Rougarou680
    Rougarou680 [OP] Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    Driver side tail light went out on my daughter's 2006 tacoma. I bought a cheap set off ebay to replace both sides. They look like the factory ones on my 13 & 14. The driver's side tail light isn't as bright as the passenger side. What should I be checking for?
  2. Sep 18, 2024 at 5:41 AM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    The only thing you can really check is voltage. You could also check the resistance of the new bulbs, but I kind of doubt you are going to see a difference.
  3. Sep 18, 2024 at 7:19 AM
    isdjww
    isdjww Well-Known Member
    Pinewood Springs, CO
    2014 AC, 4.0L, 4X4, 6-sp MT
    An easy test, though a pita, is to swap bulbs between left and right fixtures.
    If the dimness travels with the bulb, then get a new bulb.
    If the dimness stays with the fixture, then cleaning the bulb contacts may be required.
    Dm93 and 1 Limited Toyota like this.
  4. Sep 18, 2024 at 7:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Did you mean to say
    Then cleaning the socket contacts may be required? I mean he already moved the bulb in the bulb swap scenario.
  5. Sep 18, 2024 at 7:43 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Bad ground?
    69 Jim and TnShooter like this.
  6. Sep 18, 2024 at 7:48 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sounds like a ground issue to me.
    69 Jim, Jimmyh and Rougarou680[OP] like this.
  7. Sep 18, 2024 at 10:11 AM
    Rougarou680
    Lousyana
    tailight part is LED
  8. Sep 18, 2024 at 10:11 AM
    Rougarou680
    Lousyana
    I'll have to check. Where is the ground for that?
  9. Sep 18, 2024 at 10:13 AM
    Rougarou680
    Lousyana
    No bulb to remove for tail light part. It's LED.
  10. Sep 18, 2024 at 10:30 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Since it was a ebay special I'd suspect a shitty part.
    Connectors should be the same side to side so easiest thing to do would be to plug it into the other side and see if it's still dim.
    69 Jim, isdjww, Too Stroked and 4 others like this.
  11. Sep 18, 2024 at 10:32 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Thats The Post of The Day right there...
    69 Jim and Jimmyh like this.
  12. Sep 18, 2024 at 2:29 PM
    Rougarou680
    Lousyana
    Gotcha
  13. Sep 18, 2024 at 2:31 PM
    Rougarou680
    Lousyana
    I believe the ones I took off were some high dollar ones & only lasted a couple years.
    HondaGM[QUOTED] likes this.
  14. Sep 18, 2024 at 9:32 PM
    isdjww
    I didn't realize that they were LED, though I guess I should have.
    Because you are changing the whole fixture, I'm guessing that the LEDs are an integral part of the fixture and are not easily replaced.
    Doesn't eBay have a mechanism where eBay will compensate you if the seller doesn't make good on your purchase?
    I'm assuming that these weren't used (as-is) parts.
  15. Sep 19, 2024 at 6:11 PM
    Rougarou680
    Lousyana
    I plugged it into passenger side & it’s still dim so I will contact seller for a swap.
    Jimmyh and Dm93 like this.
  16. Sep 19, 2024 at 6:12 PM
    Rougarou680
    Lousyana
    Dim on other side too. Faulty light.
    Dm93 likes this.
