driver side window loose
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nobarnfarm, Apr 23, 2018.
  1. Apr 23, 2018 at 7:31 AM
    nobarnfarm
    nobarnfarm [OP] New Member
    2012 tacoma extended cab
    2012 xcab. I've been battling with a drivers side window that pops loose from the clips and falls forward since January. Dealer originally referred me to an auto glass specialist, claiming they didn't have the proper adhesive to reattach the clip (WTF??). Specialist has "fixed" it 3 times, even replaced the clips, and it just came loose again. Got my $$ back from specialist, called dealer, and they want to replace the GLASS! I asked why the glass-it's not exposed to any weathering or UV where the clips attach. It's glass for goodness sake-it doesn't break down. He just said "that's what is recommended" when I pressed for an explanation. Ended the conversation by asking him to call me back when he has a reason why the glass needs replacing.
    Any ideas from y'all?
  2. Apr 23, 2018 at 8:59 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    A lot of the times, the clips that hold the glass to the window regulator can break or slide around. Only way to really fix this is to replace the glass. Not sure what your issue is since there are no pics, but if one of those permanent clips has broken the adhesive that holds the clip to the glass it’s time for new glass. I have seen this happen before a few times.
    Skyway likes this.
  3. Apr 23, 2018 at 9:13 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    see those little clips. if they break your sol. if they urethaned them back on its just a band aid. if you live in a cold area it can put a lot of stress on the track when the window is frozen.
    Bebop likes this.
  4. Apr 23, 2018 at 11:14 AM
    nobarnfarm
    OK-I'm a bit of a newbie with repairs, thought the clips could be replaced without replacing the glass, since the glass is still intact and without any marring. Any ideas why/how the glass changes so the clips won't stay attached? (trying to learn so as not to repeat something that may have caused an issue)
  5. Apr 23, 2018 at 12:02 PM
    Bebop
    Nick
    What the glass shop probably tried to do was a band aid. Only way to truly fix it is to replace the glass. It can be done by yourself if you are mechanically capable. Don’t try to roll your window down if it’s frozen.
  6. Apr 23, 2018 at 12:20 PM
    nobarnfarm
    I've watched the how-to videos, just to get an understanding of the process. Will certainly let someone else take everything apart!
  7. Apr 23, 2018 at 12:28 PM
    hmsailor
    hmsailor Well-Known Member
    Florida
    2015 DCSB 4X4 TRD spORt
    same window also sounds weird. when i close mine, the motor seems to keep turning. the othe three just stop when closed.
