Driver Side Window Won't Roll Down
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2002TACOsupreme, Jun 28, 2017.
  1. Jun 28, 2017 at 1:33 PM
    2002TACOsupreme
    2002TACOsupreme [OP] New Member
    2002 3.4L Access Cab Silver
    I have electric windows. I left my driver side window rolled down during a rain storm. I was able to roll the window up but it won't roll back down. I can hear a distinct click when I roll it up but no sound when I try to roll it down. Anything will help, thanks.
  2. Jun 28, 2017 at 1:39 PM
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    It is possible that water entered the switch housing and damaged some electrical components. doubt it's the motor as non-programmed motors don't break just one direction. I would replace the switch housing and see if that works.
  3. Jun 28, 2017 at 2:02 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Maybe remove the Master switch and let it dry out
    At least try before buying a new one
    Might cure your issue might not.
  4. Jul 6, 2017 at 3:51 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    yeah take apart the switch and clean the contacts.
  5. Jul 6, 2017 at 4:27 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Most likely the switch as mentioned above. I had this happen to my '00 back in the day. Try cleaning before replacing.
