Driver sideview mirror wire connection
Discussion in '3rd Gen. Tacomas (2016-2023)' started by klatekin, Oct 27, 2020.
  1. May 31, 2023 at 5:22 AM
    099
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    Make sure you cut the heat shrink and peel it off before pulling the spade clip. You might pull the wire off of the clip. That was my mistake. I went with Spotter Mirrors.
  2. May 31, 2023 at 6:50 AM
    Tacospike
    Two Trucks
    Just keep working at it. The first time is the hardest. Had the same issue when I did my Tundra mirrors. Just stick with it.
    I didn't mess with any heat shrink like above, but might help?
    TRDRed likes this.
  3. May 31, 2023 at 7:34 AM
    CriusTitan
    CriusTitan Well-Known Member
    2023 TRD Offroad DCLB Icecap
    I’ll give it one more go, I don’t want to mess with it too much and give Toyota a reason to void warranty on this part if there was ever an issue because of something so silly haha.
  4. May 31, 2023 at 8:48 AM
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    I still haven’t installed mine. It’s been like over 2 years haha
  5. May 31, 2023 at 9:05 AM
    CriusTitan
    Haha, I give up, tried again this morning it doesn’t budge tore the heat shrink a little with pliers. Maybe they are using some kind of locking clip now? Saw somewhere else they had to completely rip off the mirror from the male portion.
    KrnTaco08[QUOTED] likes this.
  6. May 31, 2023 at 3:27 PM
    KrnTaco08
    LA
    2017 Taco
    there’s a pretty good YouTube video on how to install these mirrors.
  7. May 31, 2023 at 3:48 PM
    CriusTitan
    Returned them it’s not worth the trouble to me. Tried for an hour with different methods all but cutting off the shrink wrap.
  8. May 31, 2023 at 5:21 PM
    KrnTaco08
    LA
    2017 Taco
    Damn. Sorry to hear that.
  9. May 31, 2023 at 5:34 PM
    CriusTitan
    Hope you have more success than I!
  10. May 31, 2023 at 5:52 PM
    KrnTaco08
    LA
    2017 Taco
    I’ll keep you posted!
  11. Jun 4, 2023 at 2:51 PM
    099
    I have a 22 SR5. You must get the heat shrink off of the connection and then use a needle nose to pull the connection apart. Don't pull on the wire. Pull the base of the spade connector and wiggle side to side as you pull. Hope this help.
    TRDRed likes this.
  12. Jun 4, 2023 at 8:49 PM
    CriusTitan
    I may try this, does the heat shrink have glue inside? Haven’t seen any tutorials requiring the heat shrink to be removed and not sure why this would make a difference
  13. Jun 5, 2023 at 7:28 AM
    099
    I do not believe the heat shrink has glue. It is a tight fit. Make sure you get the heat shrink off of the whole connection before you pull.
  14. Jun 5, 2023 at 11:15 AM
    CriusTitan
    Thanks for confirming, I did have to remove the heat shrink and then pry up both sides of the female spade clamp a little and it slides right off. Heat shrink is not adhesive lined which is why I was a little hesitant
    TRDRed likes this.
  15. Jun 5, 2023 at 12:21 PM
    #35
    099
    Ok, good. Glad it worked.
  16. Jun 2, 2025 at 12:35 PM
    #36
    cjfly
    cjfly New Member
    cj
    Seattle
    2019 toyota tacoma trd sport
    I can not get these unplugged and there is adhesive on them i scrapped off around the edges. Still no luck...wtf
