Driver Window Help Please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Mar 15, 2019.
  1. Mar 15, 2019 at 4:28 PM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    My driver side window goes 2/3 down then slows way down - I'm afraid to let it go down further because I'm afraid it won't go back up. I have no idea how to proceed. Any response appreciated. Thanks in advance.
  2. Mar 15, 2019 at 5:21 PM
    Muddinfun
    Muddinfun Well-Known Member
  3. Mar 15, 2019 at 5:48 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Try cleaning the channels with soapy water. Mine were making a screeching sound due to road salt residue, once I washed them good it really helped.
  4. Mar 15, 2019 at 7:37 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    take the door card off and lube up the tracks, about a 10 minute jobber.
    whatstcp likes this.
  5. Mar 16, 2019 at 8:08 PM
    george3
    New Jersey
    Thanks guys - I'll try the silicone, Youtube is great - no screeching sound but I'll try soapy water too - what's the door card and how do I take it off ? Thanks for responses.
  6. Mar 16, 2019 at 8:34 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    https://en.m.wikipedia.org/wiki/Door_card
    To remove
    Even better for more detail I like this one :D
  7. Mar 17, 2019 at 5:58 AM
    george3
    New Jersey
    Please send her over immediately - I have some things she can help me with before during and after the door panel is removed. Thanks so much for prompt action in this manner.
  8. Mar 17, 2019 at 7:36 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Has your door check been broken and replaced? If so, it's easy for the broken door check to ram into the forward window track when you close the door. If that's what happened, you'll either need to replace the window track or remove it and straighten it.
    Jimmyh and 06Tacooo like this.
  9. Mar 17, 2019 at 8:32 AM
    george3
    New Jersey
    Thanks for the suggestion however fortunately my door check no been broken and replaced.
  10. Mar 30, 2019 at 5:13 PM
    george3
    New Jersey
    Update - Beautiful sunny 70F day in North Jersey - thanks for the videos - took the door panel off and found a little kink in the track on the front of the window - straightened it out a little and spread it a little - all is good. Thanks again. Nothing to do with this thread but did front brake pads too.
    6 gearT444E likes this.
