Driver Window Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Treedog69, Feb 18, 2021.
  1. Feb 18, 2021 at 4:29 AM
    Treedog69
    Treedog69 [OP] New Member
    Allen
    2014 Prerunner gray
    I bought a 2014 Prerunner today, the driver window will not operate, I have read in other threads that changing a battery could cause window problems, but never the drivers window, the battery was changed out at the dealer, any help will be appreciated
  2. Feb 18, 2021 at 4:34 AM
    Clearwater Bill
    Billy
    Largo Florida
    Never heard of a battery causing a window problem.
    You bought it at a dealer?
    Don't you have a warranty of some sort? At least 30 days or some such?
    Take it back.
    TacomaUSA likes this.
  3. Feb 18, 2021 at 6:23 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Either take it back to the dealer if it's under warranty or remove the driver's window switch and test for voltage or visual corrosion.
    Clearwater Bill likes this.
  4. Feb 18, 2021 at 9:57 AM
    Treedog69
    Allen
    2014 Prerunner gray
    A battery swap can affect window operation and could require a reset
  5. Feb 18, 2021 at 10:00 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Most likely a loose wire, bad switch or corrosion. It's a 2014 truck......7 years old.
    Pull the door panel. Start checking the wires. Then the switch. A DMM (Digital MultiMeter) can be very useful for measuring voltage, resistance......
  6. Feb 18, 2021 at 10:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    I'm willing to learn.
    Please explain how.
    And citation of sources would be helpful too.
    Thanks
    Jimmyh likes this.
  7. Feb 18, 2021 at 10:14 AM
    Muddinfun
    Muddinfun Well-Known Member
    On vehicles that use the ECU to determine window position, yes, but on 2nd gen Tacos, no.
    Does the drivers door switch panel make the other window(s) operate?
    As mentioned, the dealer should be taking care of this. If they balk, tell them it’s a safety issue. If you’re in an accident and the door won’t open, you need to be able to roll the window down to climb out.
    Jimmyh and devkurf like this.
