Driver's airbag not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sarcastro, Jan 20, 2023.
  1. Jan 20, 2023 at 8:00 AM
    Sarcastro
    Sarcastro [OP] Well-Known Member
    Trevor
    2006 Tacoma TRD
    So I replaced my clock spring on my 06 TRD sport to fix my cruise control. Now my driver's airbag isn't working. Has anyone had this issue and what steps did you take to figure out what was wrong?
    HondaGM likes this.
  2. Jan 20, 2023 at 8:03 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I’d go back and make sure everything is all connected like it should be. There is also like a gray connector you have to pull off the old clock spring and add to the new one.
    koditten and HondaGM like this.
  3. Jan 20, 2023 at 8:06 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    :popcorn:
  4. Jan 20, 2023 at 8:06 AM
    Sarcastro
    Trevor
    2006 Tacoma TRD
    Install was done correctly
    HondaGM likes this.
  5. Jan 20, 2023 at 8:06 AM
    JdevTac
    Josh
    MD/GA
    2nd gen
    Ok. eBay part or OEM?
  6. Jan 20, 2023 at 8:07 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Whats the code?
    Dm93 likes this.
  7. Jan 20, 2023 at 8:10 AM
    Sarcastro
    Trevor
    2006 Tacoma TRD
    OEM
  8. Jan 20, 2023 at 8:22 AM
    JdevTac
    Josh
    MD/GA
    2nd gen
    I’d go back and make sure all connectors are seated correctly including the 2 connectors at the airbag have the clips seated. If you have then disregard. It would be way more unlikely that you have a faulty new OEM part.
    Or get the code read. Most obd readers though won’t pull srs codes.
    Jimmyh likes this.
  9. Jan 20, 2023 at 3:41 PM
    Sarcastro
    Trevor
    2006 Tacoma TRD
    I checked all connections and afterwards had my mechanic check it last oil change. He didn't have time to do a deep dive and I'm not sure I want to pay for that. So it's not the connections. What am I missing?
  10. Jan 20, 2023 at 4:38 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What code(s) are you getting?
  11. Jan 20, 2023 at 4:47 PM
    JdevTac
    Josh
    MD/GA
    2nd gen
    Any other work done on the truck? Seat removal for any reason?
  12. Jan 20, 2023 at 6:54 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Trying to figure out what’s wrong without the code is like flying blind
    Dm93 likes this.
  13. Jan 20, 2023 at 6:58 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You do have your seat belt on, right?
    I think the air bag light stays lit if you are in the seat and not belted.
  14. Jan 20, 2023 at 7:01 PM
    JdevTac
    Josh
    MD/GA
    2nd gen
    That’s a separate dash light.
    koditten[QUOTED] likes this.
