drivers door window squeak/rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nobescare, Sep 26, 2014.
  1. Sep 26, 2014 at 9:11 AM
    nobescare
    nobescare [OP] Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    I have an 05 prerunner. whenever the drivers door window is put all the way down it rattles and squeaks like a demon. as soon as I put it up, even an inch (some pressure on the drive) it all stops.
    any ideas on a permanent fix. I've done a search but couldn't come up with anything.
    thx.
  2. Sep 26, 2014 at 12:34 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    My 06 did this.
    Google "how to remove tacoma door panel" and some nice gal in daisy duke shorts will show you how to remove said door panel.
    Then, check all bolts inside the door...I had one fall out, and two were loose.
    I watched the video five times to ensure I did eveything exactly correct...;)
  3. Sep 26, 2014 at 12:40 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    :laugh: Can't be too careful there
  4. Sep 26, 2014 at 4:40 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
  5. Sep 26, 2014 at 8:32 PM
    doorsidedown
    doorsidedown Well-Known Member
    Watched that video myself... And mine was a loose bolt.
  6. Sep 30, 2014 at 2:43 PM
    nobescare
    Mark
    2019 Highlander SE
    will watch 10 times then attempt
  7. Oct 31, 2014 at 12:25 PM
    Jeppa63
    Jeppa63 Well-Known Member
    Jeff
    2011 4x4 Sport DCLB
    My 2011 started rattling when the drivers window was down also. Glad I found this thread, it was driving me nuts......weekend project.
  8. Aug 13, 2022 at 6:15 PM
    Buzzkill657
    Buzzkill657 Well-Known Member
    Jeff
    thank you for this thread. I had two nuts back off. snugged them up and rattle is gone. so much better
