Drivers door won't unlock with key fob or switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DBF, Nov 23, 2017.
  1. Nov 23, 2017 at 7:09 AM
    DBF
    DBF [OP] Well-Known Member
    2012 Tacoma, 4x4.base model, access cab.
    2012 Tacoma. Drivers door will not unlock with the key fob or the door switch. It will unlock with the key.
    The passenger door is works fine.
    I can hear a clicking sound under the dash when I click the fob. Any thoughts?? Thanks for the help.
  2. Nov 23, 2017 at 7:16 AM
    DBF
    Thanks Crodell6. Also, I did see a mouse nest in the engine. Wonder if that would have something to do with it (chewed wire)??
  3. Nov 23, 2017 at 7:18 AM
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    Uh oh, those little rodents can cause some dammage....
  4. Nov 23, 2017 at 7:20 AM
    DBF
    Another thing I forgot to mention. The drivers door WILL lock with the key fob.
    Could it still be the actuator??
  5. Nov 23, 2017 at 7:30 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Do you hear it when using the switch?
  6. Nov 23, 2017 at 7:42 AM
    DBF
    I hear the clicking under the dash when using the switch
  7. Nov 23, 2017 at 7:44 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Time to start removing panels!!!
    DBF[OP] likes this.
  8. Nov 23, 2017 at 2:44 PM
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    I had this problem. Took the actuator out and took it apart for a little cleaning and grease and has been perfect for a few years now.
    DBF[OP] likes this.
  9. Nov 23, 2017 at 6:41 PM
    JFick
    JFick Sawzall Enthusiast
    Los Angeles
    ‘19 TRDOR 6MT, ‘11 BMW M3 DCT
    Softopper 255/85r16 Yokohama MTs Camburg UCAs King extended travel coilovers King extended travel rear shocks Firestone airbags OME medium duty leafs
    Mine has been acting up randomly for a few months now, thinking about trying to solve it. It's been getting more and more common. Not a huge deal to me, but I'd like to look into it before it's permanently an issue.
  10. Nov 23, 2017 at 7:17 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Had this happen with my back passenger door. Couple bucks on ebay for a new lil actuator motor and an hour of my time to disassemble replace and reassemble and all was good as new.
  11. Nov 23, 2017 at 9:24 PM
    Buckwheat893
    Buckwheat893 Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    try popping off the little panel on the armrest and see if it’s still connected. Same thing happened to me a while back and it turned out the connector popped off the actuator
  12. Nov 23, 2017 at 10:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Put your hand on the door close to the latch. Sometimes you can feel the actuator trying to move a little.
    If all the other door locks respond to the fob then it's probably a actuator
