Driver's seat harness won't pull out sometimes.
Discussion in '4 Cylinder' started by LDurchy, Jun 5, 2018.
  1. Jun 5, 2018 at 2:32 PM
    LDurchy
    LDurchy [OP] Well-Known Member
    Cedar Falls, Iowa
    Seems the first time I get in for the day, the driver's harness won't pull out. Dealership pulled door panel on my extended cab to check and reported all is well. Anyone else have this issue??
  2. Jun 5, 2018 at 2:33 PM
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    is your foot on the brake?
  3. Jun 5, 2018 at 2:35 PM
    LDurchy
    Cedar Falls, Iowa
    Frankly, I don't even recall if it is or not. It is to shift into R to back from garage.
  4. Jun 5, 2018 at 2:38 PM
    SilverBullet19
    Scott
    Sacramento County
    As a safety feature, the shoulder harness is supposed to lock into place (for lack of a better term) under hard braking. "Hard" is subjective. So if your foot is on the brake, it may be locking the harness. It then releases once the brake is released
  5. Jun 5, 2018 at 2:40 PM
    LDurchy
    Cedar Falls, Iowa
    Hmmm......... feet the size of mine may very well signal to the system 'hard breaking'. Will be observent next time climbing in. Thanks for the tip. :)
  6. Jun 5, 2018 at 2:44 PM
    SilverBullet19
    Scott
    Sacramento County
    no problem. For me, I often get mine "locked" when I pull out of the driveway too. Doesn't matter which car I'm in lol
  7. Jun 11, 2018 at 9:32 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Stepping on the brake while parked has no effect on the seat belt tension. If the vehicle slows suddenly when the brake is pressed, the inertia mechanism (pendulum) can activate in the seat belt retractor, and it locks.
    Sounds like the spring is just getting weak.
  8. Jun 12, 2018 at 8:12 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    For some reason the Toyotas I have observed seem to lock the seat belt when I pull too hard or fast on them when putting them on. Sometimes it takes a couple of tries.
  9. Jun 13, 2018 at 10:02 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    My 2006 access cab does this. The belt locking mechanism is overly sensitive and it's annoying. Let's hope it feels like doing it's job if/when the time comes to save my life.
    Apparently this is common in many different Toyota models: https://www.youtube.com/watch?v=mYGcUkNlZrk
    SilverBullet19 likes this.
  10. Sep 18, 2018 at 5:29 PM
    rbmount
    rbmount Member
    Rusty
    estero, fl
    '15 Tacoma extended cab
    none
    always on the third pull,not sure if foot is on the brake or not. come to think of it, the passenger side does it too
  11. Sep 18, 2018 at 5:30 PM
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    If you can’t pull out then just push and pray.
    DGXR likes this.
