Drivers Seat lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by retirednavy, Nov 28, 2015.
  1. Nov 28, 2015 at 1:06 PM
    retirednavy
    retirednavy [OP] Love my Tacoma
    Eric
    Jacksonville FL
    Does anyone know and any kit or way to lift the drivers seat of the 2015 Tacoma? The seat just sits too close to the floor for me and I'm not getting nearly enough knee bend. Thanks
  2. Nov 28, 2015 at 2:29 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Check out the seat lift link in my sig (rotate phone sideways if on a mobile). It only lifts the back of the seat to make it more bench like rather than car like. I went with the 1" lift. Makes it much more comfortable IMO and improves over hood visibility for the trail. I'm 6', I also have the bird dawg rear view mirror riser, the two go well together.
    jpmorrisvb likes this.
  3. Nov 28, 2015 at 2:48 PM
    retirednavy
    Eric
    Jacksonville FL
    Thanks, I saw that after looking around for a while, do you just raise the rear of the seat?
  4. Nov 28, 2015 at 2:57 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Correct. It changes the slope of the seat, and driving position, not sure if that would help your issue or not but I like it better. The way the front of the seat mounts to the cab, it is not easily liftable.
    You can get a rough idea what it would be like by unbolting the back seat bolts and sliding something 1" under the seat mount (a piece of 2x4 is 1.5" thick in a jam). Obviously don't drive like that, but you can test in parked to see if it is an improvement for you.
  5. Nov 29, 2015 at 2:44 AM
    retirednavy
    Eric
    Jacksonville FL
    Too bad my 2010 Matrix seats wouldn't bolt in there, they were more comfortable and you could adjust the height (rear) with a lever. I'll try the rear lift and see what happens. Thanks
  6. Nov 29, 2015 at 3:52 AM
    genequit
    genequit Well-Known Member
    Gene
    Goodyear Arizona
    white
  7. Nov 29, 2015 at 9:45 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Go with the 1" lift ... quick ... easy ... good ride position ... 6'1" 201 fyi
  8. Dec 2, 2015 at 5:21 PM
    retirednavy
    Eric
    Jacksonville FL
    I did a 1 1/2" lift and I like the seat height but the "loss of leg room" bothered me, I went to a 1/2" lift tonight and sat in the seat, the seat/leg room feels better, I'll see how the position works tomorrow on the ride to work, if not will try the a 1" next (I'm 6 also)
