Driver's Side Brake Caliper Keeps Locking Up
Discussion in '1st Gen. Tacomas (1995-2004)' started by isaacneale, Jul 25, 2019.
  1. Jul 25, 2019 at 4:48 PM
    isaacneale
    isaacneale [OP] Member
    Isaac
    '99 Toyota Tacoma
    CBI Outback 1.0 Bumper, Swing Arm
    I have a 1999 Tacoma 4x4 Base Model with 4 cyl 2.7L engine. On sunday, I was driving on the highway and the gear selector gave me a chattering noise so I pulled over. I couldn't see anything wrong in the cab or under the truck, but I was still a bit unnerved, so I started again, but this time on the side road. As I drove, I felt like there may be a transmission issue, because it felt like it was having a hard time shifting. Eventually I realized this was because my driver's side front brake caliper was locking up.
    I drove it further than I should have and burned up the piston seals so I went and picked up a new caliper and I installed it and some new pads, bled the brakes and topped off the resevoir with fresh fluid.
    I drove it for 40 miles, then it locked up again yesterday morning. Fearing it was probably the rubber brake hose, I replaced that. It drove fine for another 10-15 miles before locking up again this morning.
    Other pertinent information:
    The brake fluid does look pretty dark to me, could it be as simple as a brake fluid flush?
    It does seem to happen pretty soon after brake (seems like the fluid can get into the caliper, but can't get back out??)
    Any thoughts on what could be causing this?
    Thanks guys! Sorry if this has been addressed! I searched, but couldn't find this specific problem.
  2. Jul 25, 2019 at 7:52 PM
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    Might as well start cheap and easy: flush the brake fluid.
  3. Jul 25, 2019 at 8:03 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    What about the rotors? you may have a step in the rotor that the pad is catching on, or something like that.
    Luv my yota and isaacneale[OP] like this.
  4. Jul 25, 2019 at 8:48 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Frozen caliper I would bet. I would replace both if it were me. Check rotors and definitely bleed the brakes
    isaacneale[OP] likes this.
  5. Jul 26, 2019 at 12:38 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Look at the steel lines coming into that Caliper .
    Like you state OP fluid is getting in but not out .
    Crushed or kinked line .
    Then it is possible you got a poor quality rebuild lots of junk out there today .
  6. Jul 26, 2019 at 10:15 PM
    Macg
    Macg Active Member
    If I were just to throw parts at it I might start with the rubber brake line, they can act like that because fluid in under pedal pressure but not so much pressure to return it though a inward swollen constricted rubber tube.
