Driver's side clunk
Discussion in '1st Gen. Tacomas (1995-2004)' started by ttran, Mar 15, 2011.
  1. Mar 15, 2011 at 8:29 PM
    ttran
    ttran [OP] Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    My driver's side cv axle blew after I installed my lift and I replaced that one with a direct replacement one from Advance. All was good for about a month (no clunking or weird noises) then it started making random popping/clunking noises like it did when my cv axle was blown. I checked the cv axle and it's not leaking or anything. It clunks a heck of alot when turning and clunks occasionally while driving on roads. Any ideas?
  2. Mar 15, 2011 at 9:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How much lift you running there? Got any pics of your cv axles and their boots? You running a diff drop?
  3. Mar 16, 2011 at 2:02 PM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    A lil over 3 inches with bilstein 5100's and eibachs up front. Yes I do have a diff drop. I checked the ball joints on my uca's and my passenger one is ripped but the drivers side one looks fine and thats the one that's clunking... UCA's are added to my list now. But I don't know, for some reason I'm pretty set on it having something to do with the cv axle. My auto tech teacher installed it for me and I'm wondering if he didn't shove it back in all the way and it came loose...
