Driver's side clunking sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by feldman28, Feb 11, 2015.
  1. Feb 11, 2015 at 3:28 PM
    feldman28
    feldman28 [OP] Well-Known Member
    chris
    batavia
    09 sr5 stick
    I have a 09 ac. I'm getting a clunking sound from driver side. So I check the tire see if I can move it on ground no movement. Put it up on lift upper and lower controll arms no slop shock is fine. This is driven me nuts just started Sunday with all the snow. Any help is appreciated
  2. Feb 11, 2015 at 3:42 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sway bar end link, maybe.
  3. Feb 11, 2015 at 3:43 PM
    Aw9d
    Aw9d That one guy
    disconnect your sway bar and see if the sound goes away.
  4. Feb 11, 2015 at 3:58 PM
    feldman28
    chris
    batavia
    09 sr5 stick
    OK thanks I'll try that. What if that's not the problem
  5. Feb 11, 2015 at 4:02 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Clucking sound usually means that something is loose...
    I would do as the other members recommend and check to see if your sway bar is secured on tightly. I know from experience...
  6. Feb 11, 2015 at 4:09 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    My ds fender would thump going over bumps until I tightened it down.
  7. Feb 11, 2015 at 4:29 PM
    feldman28
    chris
    batavia
    09 sr5 stick
    Thanks guys I'll check 2mrw at work I'll bring inside and let the snow melt off.
  8. Feb 11, 2015 at 5:38 PM
    devkurf
    devkurf Member at Large
    midwest
    If it just started Sunday, and your truck has snow and ice all over the undercarriage I would wait until that all melts off and see if the noise is still there when the snow/ice is gone.
    You could very well end up wasting your time removing parts and diagnosing a phantom noise that was just ice buildup on the undercarriage.
  9. Feb 11, 2015 at 6:52 PM
    feldman28
    chris
    batavia
    09 sr5 stick
    Yeah but 90%of it melted off today it warmed up to 35 lol. The noise drives me nuts.
  10. Feb 21, 2015 at 7:10 AM
    feldman28
    chris
    batavia
    09 sr5 stick
    So sway bar is tight shocks are tight. Controll arms are good. What else could it be.
  11. Jun 14, 2015 at 6:05 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Two or three times have I heard a clunk from the front end when exiting a downhill driveway turning right.
    New truck, 1500kms, 265 70 17.
  12. Jun 14, 2015 at 6:40 PM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    ^^^ same here
  13. Jun 14, 2015 at 6:44 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Is your truck's stance modified from a stock setup?
  14. Jun 14, 2015 at 6:48 PM
    skiergd011013
    It is not.
  15. Jun 14, 2015 at 7:16 PM
    patbegley
    The Kootenays
    '22 DCLB
  16. Jun 14, 2015 at 9:43 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Check your sway bar links... mine does the same thing. Grab the sway bar in the wheel well near the link and shake it. If it is the links, you should be able to recreate it!
  17. Jun 14, 2015 at 9:45 PM
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    is your truck 4x4?
  18. Jun 14, 2015 at 10:23 PM
    patbegley
    The Kootenays
    '22 DCLB
    Mine is 4x yes
    I'll give the sway bar a shake tomorrow.
    Also give the battery a shake too - I read they can get loose but this definitely feels suspension related.
    Erks me because it's brand new.
  19. Jun 16, 2015 at 4:13 PM
    patbegley
    The Kootenays
    '22 DCLB
    Went camping. It was quite pronounced when I'd flex the suspension.
    She's going to Toyota tomorrow
  20. Jun 17, 2015 at 9:45 PM
    patbegley
    The Kootenays
    '22 DCLB
    So it was loose body mounts - mainly the right side.
    Truck was previously sprayed with Krown Rust Protection.
    Toyota reckons they must have loosened the mounts when they sprayed and didn't tighten them back up.
    I laughed.
    So far seems like they found the noise though.
    Moving on.
