Driver's side door handle broke
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kerry56, Feb 26, 2015.
  1. Feb 26, 2015 at 3:37 PM
    Kerry56
    Kerry56 [OP] Active Member
    W. Texas
    2004 5-lug SR5
    On a cold morning this week, I opened the door to my truck and the plastic handle gave a nice crisp snap as the back support on the handle broke in two. I've ordered a new one from Rock Auto, but hate working inside doors of cars/trucks. From the owner's manual, it looks like there are two bolts that can only be accessed when you take off the interior door panel.
    Anyone done this? Anything tricky about removing the door panel? I suspect this is a simple job in theory, that takes twice as long as it should simply because I'm unfamiliar with the workings of the lock/door mechanism. Plus no room for large hands inside the door.
    It'll have to wait for warmer weather no matter what.
    These are the sort of nagging problems you get with older plastics exposed to weather and repeated cycles of heat/cold.
  2. Feb 26, 2015 at 3:48 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    My passenger side broke. Im replacing it this weekend, my buddies dad is a mechanic and I watched him take it off of a donor truck he had. Didn't look to hard, but id wait till it got some what warmer. Pretty sure the door has plastic tabs on it and plastic doesn't fair so well in the cold
  3. Feb 26, 2015 at 3:50 PM
    Kchapp
    Kchapp Active Member
    Kevin
    Birmingham
    02 Double Cab SB
    General Grabber At2 on Helo He791 wheels, LED interior dome and map lights , Opt7 Led headlights, Pioneer In dash DVD, Parking brake bypass for DVD, Husky liners, Drop in UTR liner, Stainless D Cab toolbox, K&N air filter, Westin nerf bars, Mounted aux/usb input from head unit. Bluetooth OBDII module.
    Pretty straightforward. Make sure you're careful with the lock rod clip, they get brittle.
  4. Feb 26, 2015 at 7:33 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    Mine broke. Literally 90 seconds after I dropped the cash on the dealer's desk. Damn, I was pissed.
    I replaced mine. You do have to take then inner door off. The reach is a little tricky. Just be careful not to drop the nut. Slow and easy. It'll be done.
    10mm as I recall.
  5. Mar 6, 2015 at 3:16 PM
    Kerry56
    W. Texas
    2004 5-lug SR5
    Finished this today. Not a complicated job, but getting the hidden clip off the manual window crank handle is a pain in the butt.
  6. Mar 6, 2015 at 10:24 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Usually you can take an old shirt sleeve and put it under the crank and it will pull it off
  7. Mar 7, 2015 at 7:16 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Just did mine went thru the same thing last month, and that was the most difficult part. When I re-assembled it, I didn't re-use that thin, round plastic washer-like thingee that got in the way. Should be easier next time. :D
