Driver's side door issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glitcheffect7, Oct 12, 2020.
  1. Oct 12, 2020 at 10:11 AM
    glitcheffect7
    glitcheffect7 [OP] Well-Known Member
    Maine
    2014 Tacoma 6 cyl 6 spd sr5 access cab
    None, stock
    My driver's side door seems to be a little off, almost like its not closing tightly enough? I'll try to describe it as best I can...It seems harder to shut (as in harder than the passenger door) and sometimes I have to close it twice. Also, my biggest annoyance here - the door rubber gasket will make rubbing noise while driving (especially so offroad). I've been dealing with it as its not a huge issue but I recently had a Frontier rental (not sure why anyone would want one of those, just my opinion) and it was so nice to not have that sound. Any ideas on what I can do to fix this? Tightening/loosening the door hinges somehow?
    (I did use some aerospace on the rubber and that seemed to quiet it temporarily)
    Thanks for any input!
  2. Oct 12, 2020 at 2:33 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Mine will squeak if the frame “twist”.
    Usually while dropping into a shallow creek or drainage ditch, and letting one wheel drop in at a time.
    I’ve had 2 different Access-Cab trucks, they do the did it more then a single cab , or double cab.
    I guess the door supports on the double cab help with body flex. But I don’t know?
    I’ve been using low shine or low gloss armor-all on my door seals for years.
    It may not be the best thing to use, but I makes me “feel” better.
    Both trucks have wore on the front door seal that is mounted to the access door.
    And it’s not just mine, I’ve seen it on other AC trucks.
  3. Oct 12, 2020 at 5:22 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    You just need to adjust the striker on the door. It should be 2 screws that's connected to a U shaped bracket.
  4. Oct 12, 2020 at 8:48 PM
    Muddinfun
    Muddinfun Well-Known Member
    I replaced both of those on my truck. I don’t remember how much they were from Toyota, but I think they weren’t stupid expensive. It was mostly a cosmetic thing that bugged me.
    TnShooter[QUOTED] likes this.
  5. Oct 12, 2020 at 9:32 PM
    TnShooter
    Deogee
    STOCK
    I haven’t replaced mine.
    If I see signs of water intrusion, then I will replace them.
    There was a time when cosmetics matter to me, not so much any more.
    Or maybe I’m “lazy” lol
    Jimmyh likes this.
