drivers side front cv axle wheel side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mosee, May 24, 2022.
  1. May 24, 2022 at 4:19 PM
    mosee
    mosee [OP] New Member
    middle of Ontario
    2012 pyrite Tacoma TRD
    wondering if it's cheaper to replace the bearing or get a new axle?
  2. May 24, 2022 at 4:29 PM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    What is the issue you are trying to correct?
    SR-71A, PzTank and TnShooter like this.
  3. May 24, 2022 at 4:38 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    They are 2 separate things.
    You either have problems with 1 or both.
    I’d suggest finding out what the problem is.
    What is your problem?
    6 gearT444E and PzTank like this.
  4. May 24, 2022 at 4:39 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Didn’t think it’s an either or choice :notsure:
    TnShooter likes this.
  5. May 24, 2022 at 4:50 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Cheaper to buy a new axle, just buying a new axle from the dealer is only about $350 give or take, versus replacing the bearing costs not quite but nearly as much in parts and a lot more in labor.
    Don't know what you're going to do with just a new axle sitting around if you're not going to replace it, and like others have stated I don't understand why you would want to buy a new axle or replace your bearing; what seems to be the issue?
    Sounds like somebody is pumping the parts shotgun ready to unload on an issue that may not be either...
    :notsure:
  6. May 24, 2022 at 5:03 PM
    TnShooter
    Deogee
    STOCK
    The question would actually make more sense if it were the REAR axle.
    But the front, No. I’m certainly curious as to what the problem is currently?
    Key-Rei likes this.
  7. May 25, 2022 at 4:18 AM
    mosee
    middle of Ontario
    When changing my winters for summers tires I noticed the drivers side front wheel bearing dry, axle end that fits in hub also dry and dirty so I decided to replace both and also the dust cover for rotor. Winters are hard up here in the north...
  8. May 25, 2022 at 5:16 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    You should do both otherwise you’ll be doing both again in short order.
  9. May 25, 2022 at 5:19 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    The bearings are sealed, dry and dirty is 100% fine. You should never see it "wet" It's when it's leaking grease that you need to worry.
    If it makes noise thats a different story
  10. May 25, 2022 at 5:20 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Define dry? These arent supposed to be bathed in oil or anything like that, they are sealed.. The CV itself is also pretty fool proof unless there is black grease everywhere, then the boot has a hole in it
