Driver's side headlight blows out every 6 months
Discussion in 'Lighting' started by Jyles1988, Jan 3, 2017.
  1. Jan 3, 2017 at 3:35 PM
    Jyles1988
    Jyles1988 [OP] Well-Known Member
    i have a 2006 tacoma every 6 months or so the drivers head light keeps blowing any suggestion
  2. Jan 3, 2017 at 3:37 PM
    Navy Jumper
    Navy Jumper Airborne Paratrooper
    Switch to LED?
    I have also heard the oil from your fingers may cause the bulb glass to overheat.
  3. Jan 3, 2017 at 3:45 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    clean connection and dielectric grease. go back to factory head light bulbs. had the same problem in my 06. haven't had a problem since
    Jyles1988[OP] likes this.
  4. Jan 3, 2017 at 3:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    What bulbs are you running?
    What is your install procedure?
  5. Jan 3, 2017 at 5:24 PM
    Jyles1988
    the ultra bright by sylvania
  6. Jan 3, 2017 at 5:25 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    Install with bare hands and touching the bulb??
  7. Jan 3, 2017 at 5:26 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    yep same ones I was using
    Jyles1988[QUOTED][OP] likes this.
  8. Jan 3, 2017 at 5:33 PM
    kire
    kire Well-Known Member
    Seattle, Wa
    2008 Indigo Blue Tacoma AC TRD
    The brighter the bulb, the shorter they last. But some cheap ones and they will last a very long time.
  9. Jan 3, 2017 at 5:49 PM
    badger
    badger Well-Known Member
    07 SR5
    Hmmm,...I run 55/85s and they last for years.
  10. Jan 3, 2017 at 6:08 PM
    Jyles1988
    thank yall
  11. Jan 3, 2017 at 6:31 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    I got conned into buying a set of those for my 2003 Mustang some years back--they lasted about six months same as reported by the OP here.
    Did some research at that time and posted the result on a Mustang BB. I had found a Sylvania spec sheet and FAQ (the links are now broken and I cannot them it now) stating the Ultra's have a 230 hour life, and that "The life expectancy of a SilverStar halogen light source is dependent on the driver’s use of the lights, which vary by season, time of day and number of miles driven. We estimate the SilverStar halogen lights to have a life span of up to one year under average driving conditions." [emphasis added]
    Note that the specific series/model of SilverStar lamps was not specified, generally the brighter the lamp the shorter the lifespan.
    So consider that 230 hours at 2 hours/day = 115 days. If you are commuting 5 days a week, one hour each way, that is only 23 weeks--or just shy of 6 months.
    And that's all I have to say about that...
  12. Jan 4, 2017 at 6:37 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    A good bright Philips bulb should last around 400 hrs. A Philips long life bulb should be over 1000 hrs lifespan. A good relay harness should keep the voltage up and consistent vs the stock harness.
  13. Jan 4, 2017 at 8:30 AM
    TuffRuffDangerous
    TuffRuffDangerous Well-Known Member
    San Diego, CA
    2011 TRD Off Road 4x4 DCSB
    Salex glovebox/console organizers, Philips H4 MotoVision headlight bulbs, Optilux H10 Extreme Yellow XY foglight bulbs, csjumper2003 LED domelight & license plate bulbs
    My brother's Silverstar ZXR bulbs are 3 years old. I'm wondering if long duty cycles are a factor. He has driven cross country from SoCal to WI and back twice already, not to mention frequent trips to NorCal and Vegas. In the past he's had Piaa Xtreme Whites that lasted for 2 years. Other bulbs he's had (even Sylvania and Piaa) lasted anywhere from 6 months to a year or so, which is the norm for aftermarket bulbs (at least in our experiences).
    Personally on my Tacoma I've had aftermarket bulbs last about 10 or 11 months before one burns out.
