Driver's Side Heated Seat Will Not Shut Off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2kyle3, Jul 18, 2021.
  1. Jul 18, 2021 at 5:20 AM
    2kyle3
    2kyle3 [OP] Member
    Kyle
    Dartmouth, NS, Canada
    2017 Toyota Tacoma Limited
    Colour matched truck cap, power cable hardwired for GoPro, coin tray replaced with double button insert, OEM style buttons for work lights, anytime backup cam mod, motion disable switch for GPS, 2 custom overhead buttons for accessories, bed lights, custom taillights, full LED light replacement, MESO customs LED interior dome and map lights, Pedal Commander, ECT always on mod, TRD Pro grill, Raptor style grill lights with strobe function (comes on with rear work lights), rear pod lights with dual strobe function.
    So I've heard of issues where the amp stops working for the heated seats in the 3rd gen Tacoma but has anyone had their heated seats not being able to shut off?
    I thought it was the amp and I swapped the passenger and drivers side amps but it didn't make a difference. When the heated seat is set to "off" it feels the same as if one bar was illuminated.
    My only suspicion is that I recently had the dash apart so I could install the ECT always on mod and maybe I damaged something when I opened it up? I can't see any evidence of that so I figured I'd ask if anyone else has had this issue!
  2. Aug 21, 2021 at 3:30 PM
    Michael W
    Michael W Member
    Have you checked for power at the seat connector?
    You can probe the connector for voltage on the heated seat circuit and you should not detect any current if the heated seat is turned off. Sometimes heated seats are on timer circuits that cycle the current on and off to regulate the temp. I don't know if this is the case with Tacomo's or not, but I'd check it when I thought the seat felt warm.
    BTW - DO NOT PROBE the AIRBAG CONNECTOR! Unless you want a big boom. If you can't absolutely identify the heated seat circuit, don't mess with it. Take it to a pro.
  3. Aug 21, 2021 at 3:34 PM
    gwiz
    gwiz Well-Known Member
    Indiana
    2020 Tacoma SR5 4x4 V6
    GFC v2
    Maybe you got the “always on heated seat” mod by mistake?
    :p
  4. Aug 21, 2021 at 3:38 PM
    2kyle3
    2kyle3 [OP] Member
    Kyle
    So I did try to replace the climate control unit and that didn't seem to do anything either. I did disconnect all the heated seat parts, removed the feeder relay and had removed the negative battery terminal for 6 hours. One of those things seems to have solved my issue!
    I didn't touch the yellow battery connector haha!
  5. Aug 21, 2021 at 3:39 PM
    2kyle3
    2kyle3 [OP] Member
    Kyle
    I know right? It seems to be good now though! It drives how I want and the seat seems to have settled down!
  6. Aug 21, 2021 at 3:50 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    When I want ECT I just push the button.
  7. Aug 21, 2021 at 5:38 PM
    2kyle3
    2kyle3 [OP] Member
    Kyle
    I can't argue with that!
    2021SR5V64WD[QUOTED] likes this.
  8. Aug 21, 2021 at 5:47 PM
    Tripod1404
    Tripod1404 Annihilator tripod
    Serious case of swampass.
  9. Aug 21, 2021 at 5:52 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The seat airbag wire (under the seat) is yellow.
  10. Aug 21, 2021 at 6:32 PM
    2kyle3
    2kyle3 [OP] Member
    Kyle
    Honesty, probably!
