Drivers side lean, but never lifted or added a leaf???
Discussion in 'Suspension' started by TheWarthog, Jun 18, 2014.
  1. Jun 18, 2014 at 2:07 PM
    TheWarthog
    TheWarthog [OP] Well-Known Member
    Justin
    San Diego
    TRD Sport
    Debadged, Leer Cap, AFE Pro Dry S,
    I've heard of the Taco Lean, but I thought it was always from lifting a truck. I have been noticing my drivers side is a bit lower than my passenger side. Also, I have felt the front drivers side tire bottom out a couple times when hitting a speed bump a little too fast. Idk if I should be looking at a spacer, or looking for a broken part, maybe shock or coil? Or am I just bottoming out on that side because it is sitting low?
  2. Jun 25, 2014 at 6:34 AM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    I just finished installing new coils(885) and bilstein 5100's upfront. Also new skyjacker 2.5" lift leaf springs and extended bilstein 5100's. All new, and fuel thank is almost empty. I still get 1" lower(front and back) on the driver side. I think is a structural problem more than a weight problem. Of course many people here are going to give you their own hypothesis, but I could assure you, that even if I flipped sides with shocks and springs, I would still get one inch lower on driver side. Probably a manufacturer defect that Toyota has not addressed yet!
  3. Jun 25, 2014 at 6:39 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    It is normal. Has to do with all the weight being on the left side of the truck. You could order a 1/4" spacer for the front driver coil to correct the lean
  4. Jun 26, 2014 at 5:47 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    SMMarine is right. The truck overall is not balanced as one would assume.
    The fuel tank adds to the problem.
