Drivers side lean fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pportera, Apr 16, 2016.
  1. Apr 24, 2018 at 12:28 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I fixed mine mounting a hi-lift on the right side of the bed and my dog riding shotgun, it didnt take much counterweight to correct it. Without the dog, I just pack my water containers and other heavy gear on the same side too.
  2. Apr 24, 2018 at 1:12 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    so now its a 1/4" higher in the right rear? so it is hard to completely level any vehicle I guess..
  3. Mar 11, 2019 at 7:15 PM
    bartman28
    bartman28 Member
    Bart
    Louisville, KY
    2019 Tacoma TRD Sport
    Pro Grill, Valance, Rims, vinyl, significant stereo mods
    My 2019 trd sport leans almost 3/4" on the driver's side. Drives me nuts!
  4. Mar 11, 2019 at 7:19 PM
    Retumbo7
    Retumbo7 Well-Known Member
    SF Bay Area
    I can't believe Toyota lets this slide from the factory. Now I'm going to have to go measure mine...
  5. Apr 18, 2019 at 2:20 AM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    I recently put:
    OME 887
    Bilstiens 5100 all around
    ICON Leaf Mini Pack
    Took out Spring Overload in the rear (so 6 leafs total)
    1/4 spacer on front driver
    Center hub to fender is 23" dead on all around EXCEPT the REAR DRIVER.
    It's driving me nuts because it was all off but a week of driving, everything has settled nicely...but driver's rear has always been about 1" off from the driver's front. Granted I have a 1/4" spacer, but without it, driver's front would be off from FP and RP...so, I've got 3 out of 4 dead on. It's driving me nuts because I've taken measurements daily and the rear driver has always been off as everything else was settling and lining up together harmoniously. I never thought that I would need a shim because frankly I never took notice to folks in the dedicated thread with this setup ever mention it. All I saw mentioned was the front driver's side "taco lean" so I threw in the 1/4 spacer without thought off the bat. glad I did because it seems to be perfect with the FP and RP...
    I've measured with no fuel, and full tank...same thing. the measurement has NOT changed. What can be done and is it really true that even with an identical vehicle (V6 DCSB) and identical suspension to the next guy, that it can differ and no two tacomas are always going to be the same? I have nothing in my bed other than the Tonneau cover but that weight isn't much and is distributed fairly evenly so if it had an affect, I would see it equally tru on the other side (RP)...
    Is something not installed right? Preload?
    What are my options or solutions here? I'm OCD, so living with it is not one of my choices ha!
    To be fair, I have yet to do an alignment because it's only been a week and I wanted the vehicle to settle first, then align. Could that possibly help? Eye ballin' it from the front, I have no major camber, but my eyeballs aren't a great judgement to mechanical corrections. And if alignment doesn't help bring it closer, what else can I do? This is annoying! I'm anti blocks, shims and jerry-riggin which is while I went with an actual lift kit...maybe not the most lavish, but I did want to make sure it was legitimate. However, if that's the only choice I have, then I'll do what I need to!
    My front 5100 settings are on default 0, lowest setting. I have not changed them as to not stress them. So my coils upfront are bearing the load.
    I've done a search and the only solution I saw was a 1/2" shim. Can't be a defective shock, could it? All my searched here yielded this same problem with this setup on mainly 2nd gens...would love to hear 3rd gen feedback and what people have done to remedy this!
    Thanks in advance!
  6. Apr 18, 2019 at 3:43 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    The good ol Toyota lean myth.
    Vlady likes this.
  7. Apr 18, 2019 at 7:45 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Mobius Taco. Sounds like a slight difference in spring rate on leaves. Try putting a string line between the leaf mounts and measure the distance to the axle on each side.
  8. Apr 18, 2019 at 3:07 PM
    N2DesignsInc
    Los Angeles, CA
    So defective or resolvable?
  9. Apr 18, 2019 at 3:13 PM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    I prefer not to know if there is a lean... if I don’t measure, then there’s not one! Ya’ll remember how perfect your Tacoma was BEFORE you discovered this forum?
    2015TRDOR, wolfman00 and turbosnail like this.
  10. Apr 18, 2019 at 6:05 PM
    JoeCOVA
    Joe
    Colorado Springs
    Funniest part is when I measure it says the driver side is lower, when I put a level across the truck, it sits perfectly level. Which is lying?
    Speed_Munky likes this.
  11. Apr 18, 2019 at 6:23 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    The level.
  12. Apr 18, 2019 at 7:15 PM
    JoeCOVA
    Joe
    Colorado Springs
    Scissors beats rock
  13. Apr 18, 2019 at 8:15 PM
    TacoMateo
    TacoMateo Well-Known Member
    Nor Cal
    2019 DBLB TRDOR CEMENT
    I see you also use scrap mail envelopes for all your note taking needs.
    Pportera[QUOTED][OP] likes this.
  14. Apr 18, 2019 at 8:28 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    I like how you have 21 3/2" as a measurement.
    Or are these metric fractional?
  15. Apr 18, 2019 at 10:16 PM
    #35
    bagleboy
    Scott
    Norcal, Santa Rosa
    I thought the stock leaves and coils were side specific to account for the greater battery/driver/full tank but otherwise unladen weight difference so maybe you have a p- side leaf pack on the drivers side. I've also read that leaf packs can be re-arched so maybe that coukd fix it.
  16. Apr 19, 2019 at 1:38 AM
    #36
    N2DesignsInc
    Los Angeles, CA
    The ground.
    Paper beats rock.
    I'm going to park that side on some gravel and call it a day so that when I pass by, I can focus on other imperfections this forum has brought to my attention.
    NickAdams2112 likes this.
  17. Apr 19, 2019 at 1:42 AM
    #37
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I've never noticed a lean on mine either just by looking at it, and I've looked at it a shit ton of times.
    Just for the hell of it I measured it in my garage with a full tank of gas. Rear of the truck was dead nuts even, front was 1/4" off.
    I aint gonna fuck with it.
    MiamiMark likes this.
