Drivers side mirror become loose.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dirtjunkie, May 8, 2022.
  1. May 8, 2022 at 10:43 AM
    Dirtjunkie
    Dirtjunkie [OP] Well-Known Member
    Northern Colorado.
    2006-Taco-Sport-TRD-Quad Cab-Short Bed, 4x4 No mods to speak of.
    I’ve got a 2006 Tacoma that suddenly after all these years has a lose drivers side mirror. I tightened the two screws under the plastic cap on the bottom side of the mirror but it becomes lose again within two weeks. I’m tempted to use lock tight on the threads. Any better solution out there besides buying a new truck? ;)
  2. May 9, 2022 at 6:02 AM
    trktwo
    trktwo Nagger
    tommy
    biloxi
    2015 MGM DCLB TRD Sport 4x4
    why wouldn't you use locktite? i would
    ToyoTaco25 likes this.
  3. May 9, 2022 at 9:41 AM
    Dirtjunkie
    Northern Colorado.
    That's what I plan on doing. Just throwing this out there to see if this has happened to others and what they did to fix it. Sure is weird I’ve had this 2006 truck since new and now all of a sudden the mirror loosens up and continues to loosen up only weeks after tightening.
  4. May 9, 2022 at 10:41 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    I’m in the same boat with my ‘06. I’ve just learned to live with it. I’m open to suggestions too.
  5. May 9, 2022 at 10:57 AM
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    Loc-tite or get some small flat washers with a nylon locking nut.. Those whiz- lock nuts work great but once they start to wear or can't bite into the metal anymore because it's been chewed up from the nut going on and off, they won't work as well.
  6. May 10, 2022 at 6:30 AM
    Dirtjunkie
    Northern Colorado.
    Strange that once it initially became lose 16 years into its life it continually comes lose a week later after being tightened. If this is my only complaint with this model truck after 187K. I guess I can live with it.
    ZMan2k2[QUOTED] likes this.
  7. May 10, 2022 at 6:40 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
    That’s how I’m leaning. I haven’t had any problems that aren’t wear items. When it comes down to it, a couple minutes every couple weeks isn’t so bad. I may try harder to fix it if it really begins to bug me.
    Dirtjunkie[OP] likes this.
  8. May 10, 2022 at 12:52 PM
    ZMan2k2
    Richard
    Under a tinfoil hat
    Ahh…screw it! I’m gonna run with the threadlocker tip. I’ll let you know how the blue loctite works.
  9. May 10, 2022 at 12:53 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
  10. May 10, 2022 at 3:59 PM
    Dirtjunkie
    Northern Colorado.
    Yikes! Great tip but $28 a bottle.
  11. May 10, 2022 at 4:02 PM
    Key-Rei
    Key
    Florida
    Goes a pretty long way, great for classic motorcycle carb set screws, it turns gummy rather than drying out and getting brittle like lock tite and won't effect plastics like the solvents in lock tite can.
  12. May 10, 2022 at 4:12 PM
    DRMetz
    DRMetz Well-Known Member
    Drew
    DMV
    05 PreRunner SR5 TRD Sport Rad Red
    I had a similar issue and ended up having to replace the mirror. The issue was due to one of the torx screws being stripped out.
    Couldn’t take the mirror flopping forward and backwards while driving and braking.
  13. May 10, 2022 at 4:55 PM
    Dirtjunkie
    Northern Colorado.
    Do you remember how much a new mirror cost? If not I’ll check with Toyota.
    And do they come body color keyed? I’ve got the Sport package.
  14. May 10, 2022 at 5:00 PM
    Key-Rei
    Key
    Florida
    $750 ea IIRC or something equally ridiculous when I had to replace mine from trail damage, went with aftermarket ones for $150/pair but not colored or blinkers.
  15. May 10, 2022 at 5:09 PM
    DRMetz
    Drew
    DMV
    $118 and then had to get the cover color matched. They all come grey now if you have to match. If your cover is still fine and clear coat isn’t shot then you could find a cheaper one and just swap out the covers.
  16. May 10, 2022 at 5:11 PM
    DRMetz
    Drew
    DMV
  17. Nov 20, 2023 at 6:15 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    This is interesting stuff. Very popular in the firearms community. Tiny sample came with optics for sons rifle.
    Unlike loc tite you apply and use while wet with this stuff you coat the threads and let dry before assembling.
    Forms sort of a rubbery coating that supposedly isolates the fastener from vibration and thus loosening. And once applied it can be left as is indefinitely.
    This might resolve the issue of reducing torque when using loctite since VC3 isnt a liquid or lubricant when used???
    https://www.vibra-tite.com/vc-3-threadmate-overview-video/
    seems pricey but looks like a bottle last a long time.
    Have to add it may not be appropriate for any engine/transmission fasteners since its temp range only goes as high as 165F
