Drivers side seat belt soaked after rain???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingston73, Nov 14, 2024.
  1. Nov 14, 2024 at 1:28 PM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Like the title says, my drivers seat belt was completely soaked after a day of rain. No other signs of leaking anywhere, the floor is dry and the passenger side is dry. I installed an aftermarket roof rack last year and have never noticed any issues until today. I’m stumped, any ideas how this happened and how to fix it?
  2. Nov 14, 2024 at 1:30 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    It’s leaking through one of the bolts in the roof. Remove and apply a sealant to the threads on the bolt in the center of the rack.
    Jakerou, TnShooter and Marc70 like this.
  3. Nov 14, 2024 at 9:55 PM
    Norcal06Taco
    Norcal06Taco Member
    2006 Silver Tacoma TRD 4X4 DCSB
    Rigid backup lights on trigger and manual switch
    do you have a sunroof? I had a similar A pillar leak/seat belt area leak and it was a clogged drain hose for the sunroof track.
  4. Nov 15, 2024 at 8:13 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    alternatively, do you have roof rack? mine started a bit of a leak and the "mid" point for the rack is basically there!
  5. Nov 15, 2024 at 11:52 AM
    JKD
    JKD Well-Known Member
    Access cab?
    I have that problem on occasion. While it was under warranty the dealership did something that fixed it for a while, but the problem returned. I recall reading something about the way one or more of the door seal gaskets were attached and sealed to the door body panels, water would pool and then get in past the gasket fasteners.
    I need to take that access cab door panel off and just go nuts with silicone sealant.
