Drivers side speakers not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SouthernComfort, Jan 9, 2016.
  1. Jan 9, 2016 at 12:43 AM
    SouthernComfort
    SouthernComfort [OP] New Member
    Eric
    2005 Toyota Tacoma TRD Off Road
    None... Yet.
    Just bought a 2005 Tacoma and I'm absolutely in love with it. Best vehicle I've ever owned. The only issue I've got right now is that both the front and back speaker on the driver's side of the truck are not working. I verified this by adjusting the fade and balance to front left and back left. I'm wondering if there is a fuse or something that would explain this. I checked all the fuses I thought would control this, it just seems too conspicuous that BOTH the speakers on the same side of the truck are out. In the end, I'm trying to avoid taking a speaker from the right side of the truck and switching it to the left side to verify wether or not is a wiring issue or a hardware issue. Any suggestions would be great. Thanks for the help.
    taco-blob likes this.
  2. Jan 9, 2016 at 1:44 AM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    Id start with pulling the door panel and checking out the speaker. You can have the panel off in less than 10 minutes easy. It should be rather obvious if someone has been in there or if everything is stock. Possibly the previous owner upgraded the system and pulled everything out before selling it and just forgot to plug them in again. I would think you could test the wiring to see if it has power rather than switching the speakers around to but I don't know.
  3. Jan 9, 2016 at 9:24 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Well you can't exactly read a speaker wire with an ohm meter.. An oscilloscope yes you could check it. Easier to just plug in a different speaker.
    There are no fuses for the speakers...
  4. May 11, 2020 at 5:33 PM
    taco-blob
    taco-blob Member
    2012 Tacoma prerunner sr5
    2012 prerunner sr5 doing this same thing
    i have been searching the interwebs for days
    in my conclusion it has to be a failure in the amp itself
    in my experience the possibly that not only one but two speakers failing at the same time might be pretty rare
    but the drivers door tweeter still works, is it the same for you ?
    but my issue that the location of the amp is a mystery
    i have been under the dash for about an hour today
  5. May 11, 2020 at 5:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    You responded to a thread from 2016, and it was the only post he ever made.
    Long odds say don't expect a response from the original poster. ;)
    taco-blob[QUOTED] and Jojee117 like this.
  6. May 11, 2020 at 6:02 PM
    taco-blob
    taco-blob Member
    thanks i just saw that
