Driver's side water leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KodiakToyTRD, Jun 26, 2010.
  1. Jun 26, 2010 at 10:10 AM
    KodiakToyTRD
    KodiakToyTRD [OP] Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    I've read many threads about this issue and printed off the TSB for it but the TSB is only for the cowl leak. Is this "cowl leak" the primary cause of the leak in 2005 Taco's? Regardless of the amount of rain we get, I end up with visible standing water in my drivers side carpet. I've taken it thru touchless car washes without a leak but let it sit outside in a slight drizzle and bam, water in my carpet. Any help besides the TSB would be much appreciated. I live in a wet climate and this is really p!ssing me off. :mad:
  2. Jun 26, 2010 at 7:11 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    The cowl leak was for water on the passenger side. And if it were on the passenger side, then you'd have many possibilities to check off.
    Seeing as it's on the driver's side, I've seen others post about that. Are you sure it isn't happening when you drive it? Because it could be a plug underneath as the culprit. Another I remember was someone having problems with the rear window leaking. Turns out it was running down under the carpet and traveling to the front driver's floor, even though the rear carpet felt dry. I'm sure others will post up more possibilities for the driver's side based on things they've read/experienced in the past. Sorry I can't be more help.
  3. Jun 27, 2010 at 11:17 AM
    KodiakToyTRD
    CO
    Pretty sure its not happening when i drive. I drove to work about 2 days ago and it was dry, both the weather and my carpet. During the day it rained a bit...when i got in my truck to go home it was wet. I read about the rear window seals but not sure how to diagnose that. I feel a slight wetness in the carpet right along the trim on the bottom of the rear drivers side door jam (body) but i dont know if its from a rear window leak or from another leak up front trickling to the rear. Its very confusing and more then just a bit annoying because i have to vacuum it out every damn weekend!
  4. Jun 28, 2010 at 9:45 PM
    revhappyleon
    revhappyleon Well-Known Member
    Manny
    Tampa near macdill
    07 Prerunner V6 6-speed(custom dual exhaust)
    dual exhaust, foglight anytime, satoshi, chlm, aux backup lights and electric fan conversion
    I say next time it starts to rain see if you can go sit in your truck with some good tunes and a flashlight
  5. Jul 1, 2010 at 5:00 PM
    KodiakToyTRD
    CO
    Well yesterday was a nice day here so i proceeded to disassemble the interior of my truck in search of this leak. Removed the drivers seat, carpet and trim around the door, stuck a hose on the roof pointed down to the drivers side area of the windshield and turned it on. I found the leak on the body seam behind the sound insulation and the blue electrical connection box. It was a strip about a quarter inch long on the body seam where there was no seam sealer. Got some ultra black and plugged it up, and today right on cue it rains and i have no leaks.
    :bananadance:
    eljedi68 likes this.
  6. Jul 2, 2010 at 6:00 PM
    05Moose
    Jim
    Congratulations. I'm glad it didn't elude you.
  7. Jul 2, 2010 at 6:11 PM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
  8. Sep 20, 2018 at 11:40 AM
    258900 Well-Known Member
    Eddie
    BOSTON, MA
    2013 tacoma trd offroad
    debaged tailgate & doors, trd pro headlights, trd pro grille w/white surround, 4runner trd pro sema wheels, 265/70/17 pirelli a/t, morimoto fog light, klearz light smoked 3rd brake light cover, led lighting all around.
    i know this happen to you 8 years ago, but what year tacoma you had? i have a leak on the driver side now too.
  9. Sep 27, 2018 at 7:00 PM
    robbytaco
    robbytaco Well-Known Member
    Rob
    San Antonio
    06 DC TRD Sport
    I’m in the same boat with my truck. Water pooping in the driver side right under the pedals. I was under the assumption that the windshield seal was bad. Any suggestions would help. 2006 trd sport
  10. Sep 27, 2018 at 7:05 PM
    R490
    R490 Well-Known Member
    Upgrayedd
    VA
    You got a roof rack?
  11. Sep 28, 2018 at 3:54 PM
    robbytaco
    Rob
    San Antonio
    06 DC TRD Sport
    No roof rack. Also when it rains hard I get some moisture in the headliner, at the overhead console. I’m leaning toward a bad windshield seal, but I’d like to hear other people’s experiences with the leak issue. I just replaced my carpet with the vinyl floor and installed katzkin leather. When I did the floor I gave the driver side footwell a pretty good once over and nothing seemed out of sorts. I’m making an appointment this week for a new windshield anyway, mine was just cracked due to a rock. Thanks for the input.
  12. Sep 28, 2018 at 4:20 PM
    R490
    Upgrayedd
    VA
    I'll bet it's the windshield seal if it's getting in the headliner. Good luck!
  13. Oct 13, 2018 at 10:46 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Come back
