Driver's side weatherstriping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yellowgt5, Mar 11, 2012.
  1. Mar 11, 2012 at 8:17 AM
    yellowgt5
    yellowgt5 [OP] Well-Known Member
    Keith
    Cabot,AR
    2015 DCB Prerunner
    None Yet
    While cleaning up the truck yesterday, I noticed that the driver's side door weatherstriping needs replacement. I have a 2006 doublecab and I need the weatherstriping for the driver's door. Does anyone know of a good place to get it, without going to the dealership?
  2. Mar 12, 2012 at 5:12 AM
    cjthedj
    cjthedj Member
    Chadd
    WV
    06 extended cab
    I need the same, mine has a cut or dry rot area right down the vertical
  3. Mar 12, 2012 at 7:15 AM
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    Mine squeaks at highway speed. I have been considering having the dealer replace it.
  4. Mar 13, 2012 at 3:53 AM
    cjthedj
    cjthedj Member
    Chadd
    WV
    06 extended cab
    It's very easy to replace if it can be found to purchase without spending a fortune
  5. Mar 13, 2012 at 3:58 AM
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    Mine makes sort of a squeaky or wailing noise, too. Passenger's side, especially in a cross wind. Drives me insane. Looking for the best/cheapest way to fix it.
  6. Mar 14, 2012 at 7:24 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    you might be able to remedy it by applying silicone grease to the weatherstripping... silcone grease is good for rubber, and should help get it more supple and seal better..
