Drivers Side wheel sits further in the wheel well than the passenger side
Discussion in '1st Gen. Tacomas (1995-2004)' started by MarcoBro, Oct 30, 2020.
  1. Oct 30, 2020 at 9:20 AM
    MarcoBro
    MarcoBro [OP] Member
    Marco
    2004 Toyota Tacoma TRD off road
    Work in progress
    I don’t have any photos of my taco but I’m pretty sure me describing it is enough.
    Just recently I with my new wheels one side (drivers side) rubs way more than the passenger side. I know the wheels will rub but idk why there’s little to none on the passenger side compared to a lot of rubbing on the drivers side at close to full lock. It looks like the passenger wheels sits further out than the drivers side but idk why since the wheels and tires are the exact same.
  2. Oct 30, 2020 at 9:23 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Steering rack off center causes one side to turn more than other side.
    Taco critter likes this.
  3. Oct 30, 2020 at 9:30 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I have stock wheels with 265/75r16 A/Ts and my tires rubbed more on the driver side (frame) than the passenger.
    That doesn't mean the wheel is closer, it more likely that the steering geometry turns tighter in that direction (to the left).
    nothing to worry about...
  4. Oct 30, 2020 at 9:57 AM
    MarcoBro
    Marco
    Work in progress
    I will take a look at it again when I get home today and I’m gonna actually take some measurements. Hopefully after that I can get a better understanding of what’s going on.
  5. Oct 30, 2020 at 4:33 PM
    jbrandt
    Justin
    I suggest putting the tape measure away.
    It's not going to be perfectly symmetrical. F1 cars probably aren't even symmetrical.
    If it drives straight and you have a good factory alignment, there's nothing to worry about.
    Rachelsdaddy likes this.
  6. Oct 30, 2020 at 4:40 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Rubs where?
  7. Oct 30, 2020 at 4:43 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Normal. Mine does the same thing
  8. Oct 30, 2020 at 4:50 PM
    MarcoBro
    Marco
    Work in progress
    It rubs on the frame
  9. Oct 30, 2020 at 5:01 PM
    paetersen
    paetersen Well-Known Member
    Ummm. Race Car Mechanic here. When we do squaring and setup we measure and match to 10ths of millimeters. We are no where near F1 levels (just a 12 race North American series). I can gaurantee that if the track calls for it, F1 cars are set up *perfectly* symmetrical.
    but yeah, in the real world? toe and go. If it ain't crabbing and your tires are good you're done.
    Ritchie and cruxofthebisquit like this.
  10. Oct 31, 2020 at 2:49 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Mine did that with new rims- get spacers
  11. Oct 31, 2020 at 7:23 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    I’ve noticed in general I seem to be able to make tighter left turns than right turns. I think that your right that the geometry gives tighter radius to the driver side turning.
  12. Oct 31, 2020 at 7:38 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I've always said these aren't Ferrari's but F1 cars are.
    OP, the Tacoma 6 lug turns tighter than it's competitors, it does it by tucking the wheels pretty tight. At least used to, no idea about all these new big/mids coming out.
  13. Oct 31, 2020 at 8:12 AM
    jbrandt
    Justin
    I was meaning that any asymmetry was *intentional*
