drivers side window rattles when down
Discussion in '1st Gen. Tacomas (1995-2004)' started by Colt1195, Jan 19, 2013.
  1. Jan 19, 2013 at 8:09 PM
    Colt1195
    Colt1195 [OP] Well-Known Member
    I have a 2002 with 109,000 miles and power windows. Recently, when I put the drivers side window all the way down and drive, it rattles.
    I not familiar with the internals but is there some kind of dampening material that maybe wore off or something ?
  2. Jan 19, 2013 at 9:22 PM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Try tightening the 10mm nut on the lower door jamb...Worked for me. Got the tip right here on Tacoma World!
  3. Jan 19, 2013 at 9:31 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Also check all bolts behind the door panel....regulator/ect.
    Not sure what other bolts u may have available on ur year.
  4. Jan 19, 2013 at 9:35 PM
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    I've got manual windows, and when my drivers window is all the way down it squeaks/rattles. So I just don't roll it all the way down :eek:
    Soon I'll pull the door panel and tighten what I see in there, but I haven't had that much time recently
    Running Board Man likes this.
  5. Jan 19, 2013 at 9:56 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I'll bet its the window seal. It runs all the way down the window track.
    The replacement door on my drivers side (I rolled my truck) worked flawlessly. Then one day I got the idea to pull the door off of the truck and color match it to the rest of the body.
    When I couldn't pry off the window seal without pulling the entire door apart, I put the seal back in the upper part of the door.
    It's never been the same since. :(
    phx70 and GQ7227 like this.
  6. Jan 19, 2013 at 11:33 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Mine did this. Des the window operate fine? I'd guess it's coming out of the tray that lifts it up and down. Or the mount on the inside of the door is busted which happened on mine. Take off the door panel so you can see.
  7. Jan 19, 2013 at 11:38 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    This will fix most of the 1st gen window rattle problems
  8. Jan 20, 2013 at 8:09 AM
    kgw
    kgw
    SoCal
    99 PreRunner
    Try the 10mm nut first, before taking stuff apart: you could save yourself a lot of time and effort.
    Trowbocop and GQ7227 like this.
  9. Jan 20, 2013 at 12:39 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    mine only rattles when half way up/down [​IMG]
    closed or open fully... no problem
    laziness hasn't fixed it tho' !? :notsure:
    GQ7227 likes this.
  10. Mar 12, 2020 at 6:05 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    mine seems to be getting more, just noticeable started last year and only rattles partially down so far when i need some road noise or fresh & crisp spring air
    i may try the 10mm nut first
    the only thing i recall doing before this happened was to clean the run channel tracks out good with some silicone spray stuff so it would slide up and down easier, which it seemed to!?
  11. Mar 12, 2020 at 6:12 AM
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
    This is what worked for my window rattle & it took under 2 minutes to fix. Thanks!
  12. Mar 12, 2020 at 6:21 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    did you have a rattle when window was all the way down, partially down with wind or both?
  13. Mar 12, 2020 at 6:40 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Man the old threads are getting dug up a lot lately.
    Wyoming09 and Kwikvette like this.
  14. Mar 12, 2020 at 6:52 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Carry on.
  15. Mar 12, 2020 at 8:53 AM
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
    All the way down only. But I imagine the longer I left it loose, more stages of roll-up would be affected. Whilst driving only- didn't matter about cross-wind.
    GQ7227[QUOTED] likes this.
  16. Mar 13, 2020 at 3:19 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Too funny. I reconnected the battery after messing with the HU last week and just happened to walk by the open driver’s door with a 10mm wrench in my hand. I don’t know what possessed me but I looked at that bolt in the door jamb and the wrench in my hand and decided eh, give it a twist. SOB i fixed the door rattle!
    Trowbocop likes this.
  17. Mar 13, 2020 at 10:31 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Yeah, they are. But I often look at them because some contain information that wasn't important to me when the thread was active but is a lifesaver now.
    six5crèéd[QUOTED] likes this.
  18. Mar 13, 2020 at 10:40 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i just wish i would need to replace the motor or something in there, it still seems really good condition for the power windows! just an insane window rattle at most speeds going on currently
    why did i ever spray lubricant in the run channels :(
    it started soon after i did that lol
  19. Mar 14, 2020 at 10:12 AM
    skeezix
    Colorado
    1998 Limited
    Could it be that the lock knob is vibrating against the door sill? I have that and it's driving me crazy!
