drivers side window rattles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomalimited, Feb 28, 2013.
  1. Feb 28, 2013 at 8:11 AM
    tacomalimited
    tacomalimited [OP] Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
    just curious to see if anyone else has noticed the drivers side window rattle/shake when you close the door and the window is only open 1/4 of the way.is this normal?I have a 2013 tacoma dclb.thanx!
  2. Feb 28, 2013 at 9:18 AM
    03DBLCABTACO
    03DBLCABTACO Well-Known Member
    Dan
    Tomball TX
    Cavalry Blue 2019 TRD OFF-ROAD 4X4
    Normal. From what I have seen they have been doing it since 2005
  3. Feb 28, 2013 at 10:27 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    My windows rattle in all 4 corners when I'm wheeling...all the time. Down, up, and everything in between.
    JohnnyDevil likes this.
  4. Feb 28, 2013 at 11:10 AM
    tacomalimited
    Northern NJ
    guess it's normal.seems odd though.why so shaky? this is my first Toyota,not used to some things,I guess.
  5. Mar 14, 2013 at 7:22 AM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    Took my truck in for a 25,000 mile service and had them look at my driver window rattle. They fixed it. they took a piece of foam tape and placed it between the metal door and the window seal or window track. The window track it too big for the window, got to pinch it together with some foam tape. Doesn't rattle now.
  6. Mar 14, 2013 at 7:28 AM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Got pics? I've given up on tracing that rattle for the last 3 years...I've read every post on the subject and was under the assumption that it was in fact the seat belt height adjuster...but my back window rattles when I lower it a 1/2" to vent also...
  7. Mar 15, 2013 at 6:18 AM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    Don't have any pictures. they had the truck back in service. but the foam tape goes about where the mirror is under the seal between the inside of the door metal and the window seal.
  8. Mar 15, 2013 at 7:18 AM
    undecided
    undecided Well-Known Member
    Adam
    San Diego, CA
    06 TRD Sport 4X4
    CAI, CB radio, Double Din Stereo, Aero Exhaust, Softopper, BHLM, KODE Push Button Start, Bruteforce Fab Rear bumper, Weathertechs
    I had the same problem with my rear passenger window. It was a quick 20-30 minute job without knowing what I was getting into and figuring out a solution. This is not hard by any means. As long as you have the tools needed in front of you, I don't see this fix taking more than 15-20 minutes.
    Tools/ Supplies needed: Philips screwdriver, flathead screwdriver, your choice of adhesive
    1. Remove the door panel.
    1.1. Remove the top black panel from the door by removing the plastic fastener and gently pulling off the panel
    1.2. Next remove the main panel by removing the two screws behind the door latch and the "change" cubby. Pry off gently.
    2. Unhook the connector to the window switch from the door panel. I had to use a flathead screwdriver to help unplug the panel. Be careful not to break the connector.
    3. Peel back the protective plastic that covers the door. You will be able to reattach it when you are done.
    4. Look inside the door and find the weather stripping that should be laying around somewhere on the bottom.
    5. Clean the window track and apply you choice of adhesive (3M Adhesive spray OR Mounting tape)
    6. Insert the weather stripping into the window track. Be sure that the rubber connect to each other so the window will not catch on the edges and push the stripping off the track again.
    7. Test the window to see if it slides up and down without obstruction and then put everything back on. Start at step 3 and work to step 1
    NOTE: I discovered the window would not roll down from the drivers side controls without the passenger panel plugged back in. I did a fit test with the plug partially plugged back in just to make sure everything was ok then disconnected the panel and reattached the plastic.
    If you have any questions feel free to ask
  9. Mar 15, 2013 at 7:25 AM
    undecided
    Adam
    San Diego, CA
    06 TRD Sport 4X4
    I will upload pics in a few days I am on vacation right meow. :D
  10. Jul 5, 2014 at 8:37 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I just did this to my 2012. Sure enough it was the track weather strip. So i put the weather strip back in the track and made sure the window worked correctly by rolling it up and down a bunch of times to make sure it works smoothly.
    Put everything back together and now im rattle free. :)
  11. Jul 10, 2014 at 7:11 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
  12. Feb 4, 2016 at 4:17 PM
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
