Drivers turn signal blinking too fast when braking
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2tufftaco, Dec 29, 2012.
  1. Dec 29, 2012 at 2:13 PM
    2tufftaco
    2tufftaco [OP] Member
    orlando
    02 prerunner
    ive searched for a solution and i got nothing ,has anyone experienced this, both front and rear lights blink fast... bulbs are fine checked/changed etc. only drivers side blinks fast when i step on the brakes and when i let off ,they blink at normal speed any help would be appreciated tia
  2. Dec 29, 2012 at 2:28 PM
    sleeper8406
    sleeper8406 Well-Known Member
    Relay perhaps?
  3. Dec 29, 2012 at 3:29 PM
    2tufftaco
    orlando
    02 prerunner
    i thought the same thing ,could be the relay but since its only blinking fast only on the drivers side front and rear i figured it was something more complicated i will give that a shot and see
  4. Dec 30, 2012 at 9:23 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    When you "changed" out the bulbs,what did the plug end look like.???
    The "Flasher" itself,I have seen these go BUT usually not intermittently like yours....
    '01 Camry had just one light act "nuts" when brake was applied and I ended up cleaning all the plug tips with a small wire brush;then replaced that 194 side marker bulb...Everything went back to "normal"..
    My '02 Tacoma used to LOVE plate & side marker light bulbs until I smartened up and put dialectic( spelling ??) grease on them.;)
  5. Dec 30, 2012 at 9:27 AM
    Ming42083
    Ming42083 Member
    Adam
    Peoria, IL
    2012 reg cab 4x4
    weak ground?
  6. Dec 30, 2012 at 12:07 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Check your brake lights, a lot of times by design when a brake light is out your blinkers will go rapid to get your attention (it did) & to start looking around for issues....
  7. Mar 11, 2013 at 3:11 PM
    tacoma4x4driver
    tacoma4x4driver Member
    01 v6 4x4 extcab
    SAS
    What did you end up finding out? My left side is also blinking fast. All the bulbs are working. Thought about just buying another relay, but found this post and got curious if the flasher fixed your issue.
  8. Mar 11, 2013 at 7:02 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    i had the same thing recently. i found one of the bulbs was bad. when i repalced it, all was good.
  9. Mar 11, 2013 at 7:45 PM
    Murph
    Murph Go Pack Go!
    Tyler
    Fox Valley, WI
    2000 Extra Cab TRD O/R
    3" lift. American racing 15'' rims. 33x12.50 BFG A/T tires. tool box. ARB bumper, mile marker winch, kc highlights. No carpet inside sprayed with bed liner. Kicker door speakers. Alpine head unit.
    My driver side blinker blinks really fast all the time. Same scenario on my buddy's 98. I've tried bulbs and relays to no avail :mad:.
  10. Mar 11, 2013 at 7:51 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    maybe flasher?
  11. Mar 11, 2013 at 7:57 PM
    TacoSkeet
    TacoSkeet 'MERICA
    Steven
    Memphis, TN
    03 DC Tacoma
    my friend did the fog light mod and his blinkers were hyperblinking, but only when he puts the brakes on. He just got an LED resister and put it in line of the blinker and that fixed it
  12. Mar 11, 2013 at 8:05 PM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    sometimes blinker bulbs that toyota uses are dual intensity (has two filaments) but only use one filament. I havent replaced a light in a while, but you should have three contacts on the style that has dual intensity, if it has one of these bulbs, maybe its plugged in backwards so the marker light filament instead of the proper filament, or the ground is incorrectly connected to the bulb, im not saying it is or it isnt, just thinking out loud on a forum, also, do you have a tow wire harness? check it for shorts or broken wires that are shorting to something metal, or from wire to wire, my .02, not asking for a shitstorm!!!!
    also if you're going to check bulbs, check the proper plug placement for the brake lights, it may have one of these bulbs too...
  13. Mar 12, 2013 at 3:31 PM
    2tufftaco
    orlando
    02 prerunner
    i dont know what to make of it but mine just stopped blinkung fast on its own .i didnt do anything different or try anything to fix it just started blinking normal again when braking .
  14. Jun 22, 2019 at 2:11 PM
    Paul Specht
    Paul Specht New Member
    Paul
    2001 Toyota Lunar Silver Tacoma TRD
    N/A
    I have a 2001 Toyota Tacoma and it has developed the same issue in the past year. I replaced the break light bulbs cause they were burned out causing the issue. Within 3 months turn signals started blinking fast once again and every once in a while when I hit the breaks they were blinking normal again. I am going to pull off break light bulbs and try a wire brush. They are grouding out for some reason.
