Driveshaft and U joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Desert rata, Aug 23, 2021.
  1. Aug 25, 2021 at 12:49 PM
    chubbydude
    chubbydude Active Member
    The hard part is getting them off. I use a thin cut off wheel on the grinder to make a cut inboard of the ears. Then you are only hammering out one cup out at a time, makes it easy. I have not checked if a sawzall with diablo blade would also work, less messy??
  2. Aug 25, 2021 at 3:57 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    "A vise is used to remove the u-joint by pressing the bearing cups out. A small socket is positioned over one bearing cap (use a socket just slightly smaller than the diameter of the bearing cap) and a larger socket is placed over the opposite bearing cap to receive the cap as it is pressed out of the yoke by tightening the vise."
    I've used this method^^^^^ It's a lot better than using a hammer I just used old sockets I never use anymore and a thick round metal shim I had laying around. Nice and slow on the vice, and it's a DIY press.
    Jimmyh likes this.
  3. Aug 31, 2021 at 6:21 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    Where did you pick up the replacement nut you mentioned?
    What is the min size of a 3-jaw puller to pull off the carrier bearing?
    Thanks
  4. Sep 1, 2021 at 7:27 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The nut was purchased at the local Toyota dealer. IIRC, cost was <$2 with tax.
    Didn't use a puller. Father-In-Law used a pneumatic chisel with a hammer point. The bearing was shot. It came off in pieces. Outer race, then inner race.....
