Driveshaft angles... What size shims?
Discussion in 'Suspension' started by cfree5119, Jun 11, 2015.
  1. Jun 11, 2015 at 8:56 AM
    cfree5119
    cfree5119 [OP] Well-Known Member
    What size shims should I get?
    08 Dcsb 4x4, ome 885 in front, ome rear shocks, icon aal on stock leaf spring.
    Working angles from front to back.
    Tc to first shaft, 4.7
    First shaft to second, .5
    Second shaft to rear pinion flange 3.0
    Thoughts? High speed vibes starting at 40 mph. Can see bed shake in side mirror and feel it.
    Thanks
  2. Jun 13, 2015 at 6:55 PM
    cfree5119
  3. Jun 13, 2015 at 9:49 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    You're rear working angle 3* should match the middle working angle 0.5*. Sounds like a 2.5* axle shim is in order. The front working angle is just an oddball.
    4crawler.com
  4. Jun 13, 2015 at 9:51 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  5. Jun 17, 2015 at 4:41 PM
    cfree5119
    I have heard that the shims don't necessarily translate to and exact change. How do I know if my center pins are long enough? Thanks
  6. Jun 21, 2015 at 10:37 AM
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    I believe most shims come with new center pins. I'm looking to get some as well.. I lifted the back 2" so I figure I will just get 2' shims and go from there..
