Driveshaft balancing question
Discussion in '1st Gen. Tacomas (1995-2004)' started by ChinoXL, Jul 23, 2024.
  1. Aug 4, 2024 at 9:05 PM
    #41
    ChinoXL
    ChinoXL [OP] Well-Known Member
    95 Tacoma V6 MT 4x4 Xtracab
    Same symptom still there. You mentioned something to me about wheel bearings a while ago and you may be onto something
  2. Aug 5, 2024 at 3:39 AM
    #42
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    ChinoXL[OP] likes this.
  3. Aug 5, 2024 at 4:37 AM
    #43
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    When was the last time you checked/replaced wheel bearings and front brakes?
    I was chasing a vibe for 2 years, and I went down the same path (minus doing rear brakes, but I bought the parts). I did front wheel bearings, and a brake job up front. Also you should be changing your brake fluid every 2-3 years. (My vibration turned out to be the driveshaft)
    Luckily there are some free checks that you can do before ordering parts for wheel bearings. Lift up the front of the truck on stands. Grab the tire at 12 and 6 (like on a clock) and try pushing/pulling the top and bottom. If you have any movement/clunk you need wheel bearings. Also alternatively, do that same motion at 3 and 9 to check your outer/inner ball joints. Any play, those need to be replaced too.
    And since you have a 1st gen, don't the front lower ball joints go bad and potentially have catastrophic damage if they break? **ill let others chime in on that** but plan for OEM LBJs in terms of cost?
