Driveshaft busted up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mohedano1, Oct 18, 2019.
  1. Oct 18, 2019 at 1:26 PM
    Mohedano1
    Mohedano1 [OP] Well-Known Member
    Ogden, Utah!!
    '15 4wd DCSB TRD Offroad
    Total Chaos uca, King 700lb extended coilovers, King Tundra rear shock w/resi, BruteForceFab Hybrid front bumper, BruteForceFab rear HC bumper, BAMF skidz. 315/75/16 cepek extreme country, 4.88 gears, front arb locker. Rci sliders and diff skid
    Its actually a paper bag. Toyota added this paper bag feature because they knew these shafts would break apart. Toyotas paper bag feature is great, shaft breaks apart and you just pull the paper bag out from inside so you can collect your driveshaft parts and put them in the bag. Zero impact on the earth, pack out what you pack in on the trailz!!
  2. Oct 18, 2019 at 1:33 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Bahahhahah thats uh... interesting.
  3. Oct 20, 2019 at 1:28 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    It's to lessen the driveshaft harmonic hum i.e. cut noise coming off the shaft. If hollow you may get a slight ringing as with some aftermarket ones. As for balancing a 2 piece I would guess they simply balance each section alone.
    Gunshot-6A, JC15Taco and Chris(NJ) like this.
  4. Oct 20, 2019 at 6:46 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I was going to say, it must have some type of dampening effect. As funny as it is, I'm sure they wouldn't have put it there for no reason.
    Gunshot-6A likes this.
  5. Oct 20, 2019 at 6:52 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    What's the downside to a 1pc shaft on a street truck? I don't think think I've seen many complaints about them.
  6. Oct 20, 2019 at 10:52 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I've never seen any downsides to a 1 piece driveshaft but they do have limits on length and the diameter would be increased for a given length and there is also a critical speed which it is limited to. I got a scrap driveshaft from a 4runner which already has the double cardan built in and had a local place extend and balance it, no issues for the last 7 years.
    Taco-Obsessed likes this.
  7. Oct 20, 2019 at 10:54 PM
    Mohedano1
    Ogden, Utah!!
    The down sides would be clearance for wheelin', regearing 4 larger tires spins shaft 2 fast, double cardon would be weaker due to smaller ujoint. So for me its a no go.
    MolonLabeTaco likes this.
  8. Oct 21, 2019 at 12:37 AM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Why on good green earth would you not want a one piece? I sent years of time and thousands of dollars trying to make the two piece work. $850 Rene at USADriveline made custom one piece 4" aluminum shaft... Not exaggerating, litterly better than the day I drove it off the show room floor. Brand new! And that's after a 7" lift and 35's!
    Go one piece, save your money and headache and do what you gonna have to do one day anyway! :)
  9. Oct 21, 2019 at 12:39 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    4" aluminum shaft
  10. Oct 21, 2019 at 12:41 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    No it's not a one piece on a 2WD, look a it
  11. Oct 21, 2019 at 1:01 AM
    Mohedano1
    Ogden, Utah!!
    7" lift and only have 35s? Im tryin to keep center of gravity low, im on 35s 2.5" lift. Thanks for your input
    stickyTaco and MolonLabeTaco like this.
  12. Oct 21, 2019 at 1:02 AM
    Mohedano1
    Ogden, Utah!!
    Some one already answered this, thanks again for your input
  13. Oct 21, 2019 at 1:09 AM
    Mohedano1
    Ogden, Utah!!
    4"aluminum would be less tolerant than the stock steel 3"(i think) to light damage and less clearance. Thanks for the input
  14. Oct 21, 2019 at 1:12 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Doesn't matter the height, lifted is modified and screws up the entire geometry of the 2 piece. I spend hundreds of hours deling with it at 2.5", 3", etc also. I went through at least 3-4 center bearings at 3".
    I did double, double cardon I n my bronco2 with 13" lift, didn't do well. Stick to good old fashion one piece and u-joints and be done with it. :)
    All that out of the way, 35's with 2.5" lift.... What route did you take? Coil overs and fiber glass?
  15. Oct 21, 2019 at 1:15 AM
    #35
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    With that little amount of lift, you would have to cut center bearings mounts for sure for clearance. Reason for 4" alum is to make changes stregnth of 3" steel
  16. Oct 21, 2019 at 1:27 AM
    #36
    Mohedano1
    Ogden, Utah!!
    Im not a hardcore wheeler by far but for what i have done 2 the truck its alright. I have done deep cab mount chop and need 2 relocate eventually. 2.5" or so trim on fenders, hammer fender wells and still rub on full compression. Full skids,etc..Always somethin 2 tweek and tune. Runnin, the medium trails at moab, top of world, poison spider, golden spike, gold bar rim. Front arb locker, electric stock rear locker, 4.88 gears which i just blew bout 7 teeth off ring gear at moab, lol
  17. Oct 21, 2019 at 1:28 AM
    #37
    Mohedano1
    Ogden, Utah!!
    Guess our trucks go different places and are adapted differently.
  18. Oct 21, 2019 at 1:32 AM
    #38
    Mohedano1
    Ogden, Utah!!
    And i have dakar 95 with 3 degree shim so driveline geometry/angles are good on my truck. Why did you spent hundreds of hours trying 2 get geometry correct on a 3" lift? Did u measure drive line angles and use pinion shims?
  19. Oct 21, 2019 at 1:38 AM
    #39
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    So if you break-down you have fire-starting material. handy.
    That was my nickname in college :(
  20. Oct 21, 2019 at 1:46 AM
    #40
    Mohedano1
    Ogden, Utah!!
    That was my nickname in college :([/QUOTE]
    Its ok buddy, remember its not the size of the boat, its the motion in the, oh fuck we all know thats bullshit. Just get rich and bitches be all over that 4" aluminum shaft and tellin u its the best they ever had
