Driveshaft disconnect
Discussion in 'New Members' started by nmi, Jul 21, 2012.
  1. Jul 21, 2012 at 9:43 AM
    nmi
    nmi [OP] New Member
    nw fla panhandle
    08 accesscab sr5 2.7 auto
    I had a REMCO driveshaft disconnect installed so I could pull behind my RV, I had a vibration around 60 mph, I was told REMCO doesn't balance their driveshafts, so I had it balanced and re-installed. When they were doing the re-install, they said the center bearing needed replacing, the rear transmission mount needed replacing. Approximately 9 months and 2000 miles occured between the initial install and the re-install. I still have a slight vibration around 60 mph, not as bad as it was but it's still there. Does anyone have any ideas or suggestions?
