Driveshaft grease fittings,2021 2.7 extended cab 4x4
Discussion in 'New Members' started by Partschanger 2, Nov 27, 2021.
  1. Nov 27, 2021 at 5:55 AM
    Partschanger 2
    Partschanger 2 [OP] Member
    Wisconsin
    2021 Tacoma SR extendedcab 4 wheel drive.
    None
    Just bought 2021 tacoma extended cab 4x4 and I'm wondering if the driveshaft has grease fittings.
    My 2007 had grease fittings.
    Thanks in advance
  2. Nov 27, 2021 at 5:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Best way to know is to look and see..........while you're checking out all the other underpinnings.
    Key-Rei likes this.
  3. Nov 27, 2021 at 5:58 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    It's worth a look under the taco
    buckhuntin-tacoma likes this.
  4. Nov 27, 2021 at 5:58 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Yes, zerks. Should be (don't hold me to this b/c it's been a minute since I did them and I have a 4Runner too, so I get cornfused) 6 total for the 4wd.
    2 on the driveshaft just forward of the rear diff, at the joint. 2 at the prop shaft. 2 more at the other joint behind the front diff.
    A few of them are kind of a PITA to access since you have to move the truck slightly to get them to line up right.
  5. Nov 27, 2021 at 6:04 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  6. May 31, 2022 at 3:55 PM
    Partschanger 2
    Wisconsin
    None
    Well I finally crawled under my 2021 4cyl 4 wh drive automatic transmission cab sr extended, even though I get dizzy crawling under things, to look for grease fittings. Now I know, there aren't any! Absolutely no grease fittings! Way different than 2007 extended cab with the v6 engine
    Thanks to all for the replies
  7. May 31, 2022 at 4:04 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
