Driveshaft issues !
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Aust1n11, Sep 6, 2019.
  1. Sep 6, 2019 at 9:29 PM
    #41
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    My statement still stands. Name your location and we will point you towards capable hands
  2. Sep 6, 2019 at 9:29 PM
    #42
    TireFire
    Olympic Peninsula
    Lol, what?!?
  3. Sep 6, 2019 at 9:29 PM
    #43
    Aust1n11
    Aust1n11 [OP] Well-Known Member
    Tacoma sr 2.7 2019
    3 in leveling kit 33 tires 20 in rim
    I didn’t had a Toyota tech do it
  4. Sep 6, 2019 at 9:29 PM
    #44
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Meh. Be conservative. It's fine. 2" is perfectly fine.
    BlazinBlueTaco likes this.
  5. Sep 6, 2019 at 9:30 PM
    #45
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    So, the noise comes from the front of the truck?
  6. Sep 6, 2019 at 9:30 PM
    #46
    bigmw
    bigmw Not-So-Well-Known Member
    Northeastern Ontario
    2016 Blue DCSB Sport 4x4, manual transmission
    Bunch of different mods
    If this wasn't one of them "Friday threads" , it is quickly becoming so
    Hobbs likes this.
  7. Sep 6, 2019 at 9:31 PM
    #47
    Aust1n11
    Tacoma sr 2.7 2019
    I’m in Jacksonville Florida man if you know someone I can go see I’d be very greatful
  8. Sep 6, 2019 at 9:32 PM
    #48
    TireFire
    Olympic Peninsula
    I’m literally on the other side of he country but go to site navigation and look for the regional Florida thread. Those guys will sort you out
  9. Sep 6, 2019 at 9:33 PM
    #49
    Skydvrr
    Nick
    YMH
    Black '17 OR
    For me personally, I'll level it and that about as far as I'll push it. I bout mine for reliability. Changing CV boots and wheel bearings is not why I spent the extra coin.
  10. Sep 6, 2019 at 9:33 PM
    #50
    Aust1n11
    Tacoma sr 2.7 2019
    One inch block
    Hobbs[QUOTED] likes this.
  11. Sep 6, 2019 at 9:34 PM
    #51
    Hobbs
    Yep…
    Click this link to see Florida TacomaWorld regional.
    Florida
    TireFire likes this.
  12. Sep 6, 2019 at 9:35 PM
    #52
    Hobbs
    Yep…
    OK, that's not bad. How about the front end? Springs? Spacers?
  13. Sep 6, 2019 at 9:35 PM
    #53
    TireFire
    Olympic Peninsula
    So axle wrap most likely. Blocks will increase the axles leverage on the springs which are very flimsy to begin with
  14. Sep 6, 2019 at 9:37 PM
    #54
    Aust1n11
    Tacoma sr 2.7 2019
    Spacers I believe idk I didn’t do the lift all I know is he add a piece of metal on top of the spring and he said that it’s three inches and with the one inch block on the back it sits level
  15. Sep 6, 2019 at 9:38 PM
    #55
    TireFire
    Olympic Peninsula
    They’re fine on full size trucks with stiff springs. Just need to be set up by someone with brain
    Skydvrr likes this.
  16. Sep 6, 2019 at 9:39 PM
    #56
    Aust1n11
    Tacoma sr 2.7 2019
    So you think the one inch block is causing axel wrap and that’s the clunking noise I’m hearing
  17. Sep 6, 2019 at 9:41 PM
    #57
    Aust1n11
    Tacoma sr 2.7 2019
    So what do I do man how do I get this thing riding smooth again? Cause it’s 2019 and I hate driving it to be honest
    Hobbs likes this.
  18. Sep 6, 2019 at 9:41 PM
    #58
    Hobbs
    Yep…
    Sounds like he put a 3" spacer lift in the front end. If I were looking at your truck, I would take a good look at the front suspension.
    I base this on you telling me the noise comes from the front end of the truck and the lift installer put in a 3" spacer.
  19. Sep 6, 2019 at 9:42 PM
    #59
    Aust1n11
    Tacoma sr 2.7 2019
    What do I need to look for?
  20. Sep 6, 2019 at 9:45 PM
    #60
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    So... 3 pages of back and forth on a poor picture.... inconsistent clunk....
    Nobody has said what has solved others issues of strange clunking....
    Rear clunk;
    A)Grab some zap straps, grab your spare tire tools crank you spare up to make sure it’s tight then zap strap your spare chain as it might be swinging back there hitting the rim.
    B) recheck torque on all bolts from lift.
    C) make sure all bolts on rear shackles are facing correct directions, not hitting anything while flexing.
    Front clunk;
    A) Lower control arm bolts check torque.
    B) sway bar into the coils.
    Drive shaft;
    A) grab a digital level and seriously compare two trucks on same flat ground what degree’s each segment is sitting at.
    **side note carrier bearing drops are the stopping point, using shims comes into play as well to change diff angles. (I have 2.75 inch rear lift and haven’t dropped my carrier bearing.)
    Aust1n11[OP] and Hobbs like this.
