Driveshaft issues !
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Aust1n11, Sep 6, 2019.
  1. Sep 6, 2019 at 9:46 PM
    #61
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    In my opinion, a 3" spacer lift on the front of your truck makes it difficult for the front suspension to operate properly.
    If I were you (and I say this knowing I don't have the full story regarding your truck) I would remove the 3" spacers and install 2" spacers and see if the clunk and vibrations change or disappear.
    Ducman82 and BlazinBlueTaco like this.
  2. Sep 6, 2019 at 9:46 PM
    #62
    Aust1n11
    Aust1n11 [OP] Well-Known Member
    Tacoma sr 2.7 2019
    3 in leveling kit 33 tires 20 in rim
  3. Sep 6, 2019 at 9:49 PM
    #63
    Hobbs
    Yep…
    I would certainly follow CZ5ANM's advice here.
  4. Sep 6, 2019 at 9:51 PM
    #64
    Aust1n11
    Tacoma sr 2.7 2019
    I didn’t think a simple 3 by 1 leveling kit could screw with my truck so much thought these things could handle simple lifts and 33s kinda why I bought the truck
  5. Sep 6, 2019 at 9:52 PM
    #65
    Aust1n11
    Tacoma sr 2.7 2019
    I don’t think my tires will clear with me switching to 2 inches
    Hobbs[QUOTED] likes this.
  6. Sep 6, 2019 at 9:55 PM
    #66
    Aust1n11
    Tacoma sr 2.7 2019
    I will just need to learn where to find these parts
  7. Sep 6, 2019 at 9:58 PM
    #67
    Aust1n11
    Tacoma sr 2.7 2019
    So what if I changed my lift to a suspension lift is this heatheir for my truck
  8. Sep 6, 2019 at 10:03 PM
    #68
    Aust1n11
    Tacoma sr 2.7 2019
    Yes
  9. Sep 6, 2019 at 10:06 PM
    #69
    Aust1n11
    Tacoma sr 2.7 2019
    What’s the best way to lift it ? I like the height I’m at don’t want it taller or lower everything clears perfectly only problems are the vibrations and clunking on acceleration
  10. Sep 6, 2019 at 10:11 PM
    #70
    Aust1n11
    Tacoma sr 2.7 2019
    Soo I need to take off my carrier barring drop and go back to stock and add shims ?? Of what degree and should I just add leaf springs and get rid of the block?
  11. Sep 7, 2019 at 6:16 AM
    #71
    Nice96
    Nice96 Well-Known Member
    Gary
    1996 Toyota Tacoma 4x4 v6 sr5fireenginered
    Slight lift
    This problem is consistent with most lifted and leveled trucks had same problem that's why now I stay stock they look good lifted but constant problems everyone I know who lifted had same issues so how to fix it is two ways I only know sell the truck it's gone problem solved or go back to stock and take off your lift kit sorry but a fact of life or just deal with it
  12. Sep 7, 2019 at 6:55 AM
    #72
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    I had a 1.25 block in my truck for a year and never had issues. No carrier drop or shim.
    I’ve got 2.75 in the rear currently and run a 3 degree shim. No carrier drop.
    My co worker had bought a 2018, same DCSB, I compared drive line to mine an I was only out by half a degree on final drive shaft into rear diff. (current setup of 2.75)
    In your case you have a 2.7L so guessing you’re not a double cab, so you’ll have to work off your buddies truck. Or even crawl under a dealership truck to see where you should be at.
    https://m.youtube.com/watch?v=Idk3BVDVHq4
    Watching this video doesn’t make you an expert —-but at least gives you and idea of what might be happening. Lol
    One more thought I had just know is that if you throw 400-500 pounds of what ever in the bed does the noise go away? (Obviously weight will change last drive shaft angle)
    ShirtTucker likes this.
  13. Sep 7, 2019 at 8:45 AM
    #73
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    These trucks can easily handle simple 3” lifts but a stupid spacer lift is another level.
    Fix your truck by removing it entirely.
    A clunk is pretty generic, it could literally be anything.
    When lifting you may not need the CB drop and you may not need shims, maybe you need both or a combination. Shims are usually 1 degree per inch of lift.
    I’m lifted 3 inches front and rear and run neither. No vibes or clunks.
    Tacomaworld is a compendium. I recommend you spend some time reading and researching so when you make changes to your truck you are fully informed.
    Not true at all, problems are exceptional and are easily diagnosed.
    Aust1n11[QUOTED][OP] likes this.
