Driveshaft nut... the one on the output shaft from the transfer case.
Discussion in 'Georgia' started by Glockster22, Sep 13, 2020.
  1. Sep 13, 2020 at 7:30 AM
    Glockster22
    Glockster22 [OP] Well-Known Member
    2005 tacoma
    Ironman lift
    I replaced the u joints on my 2005 4x4 tacomas and somehow lost one of the 11mm, 1x30 nuts for the front connection. I know it's a longshot, but, Im in the Buford, suwanee area. Anyone got one?
    Local dealers are out, or not open today.
  2. Sep 13, 2020 at 10:12 AM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    Id pop one off and take it to your local auto parts store and see if they can measure it and maybe they’ll have one for you
  3. Sep 13, 2020 at 10:15 AM
    Glockster22
    2005 tacoma
    Ironman lift
    Did that, well, hit ace hardware's fastener section. Lots of 10mm and 12. No 11mm. Everything else was closed. Thanks for the idea though!
  4. Sep 13, 2020 at 10:26 AM
    My Name is Rahl
    11mm is oddball metric diameter. No one is going to have one on the shelf.
    You're better off waiting for Monday and getting one from the dealer.
    Or, here are a couple you can get from Fastenal.
    https://www.fastenal.com/product/fa...read+Size&selectedAggregation=Dia/Thread+Size
    Those are the standard coarse and fine threads for the 11mm nut. I didn't really understand what thread pitch you meant by 11mm, 1x30.
  5. Sep 13, 2020 at 10:30 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    One of the 4 that connects the front of the driveshaft to the T case? I have one, but im in VA
  6. Sep 13, 2020 at 1:24 PM
    Glockster22
    2005 tacoma
    Ironman lift
    Yeah those are the ones... I'll just hit the dealer tomorrow.
    Thanks.
  7. Oct 22, 2020 at 6:27 PM
    Glockster22
    2005 tacoma
    Ironman lift
    I ended up having a set from a local dealer. Funny story... just this past weekend I pulled the 2 rear most skid plates... among the mud and rocks that fell was the nut. I had done this when I lost it and found nothing. I think it was in the frame cross member and finally rattled close enough to a hole to fall out... now I have an extra set.
    Airmain likes this.
