Driveshaft problems, I screwed up maybe you can help me!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NewfoundlandTaco, Dec 9, 2016.
  1. Dec 9, 2016 at 5:59 AM
    NewfoundlandTaco
    NewfoundlandTaco [OP] Well-Known Member
    Newfoundland, Canada
    06 TRD Offroad Indigo Ink
    Billy 5100 at 2.5", 1.5" blocks, tailgate theft mod, extra bed D-rings. General Grabber AT2's.
    Hey guys, replaced my carrier bearing last weekend and middle U-joint on my 2006 4x4 access cab. Forgot to mark the driveshaft when taking the middle u joint apart. Still have some vibration but not as bad. There's a 50%chance I put the driveshaft back together 180 degrees out of phase. So here's where I need help. The front and rear u-joints are original with the grease nipple in the end caps. When the truck comes from the factory are the grease nipples all in a straight line on the rear driveshaft?
  2. Dec 9, 2016 at 6:28 AM
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    Mine are in a straight line on my 2009.
    TacoCat likes this.
  3. Dec 9, 2016 at 3:38 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Yes all in line. But if you take it to a driveshaft place they will separate balance and make adjustments if needed.if not it is 180 out.
  4. Dec 12, 2016 at 5:57 AM
    NewfoundlandTaco
    Fixed it this weekend, back to normal. Thanks
  5. Dec 12, 2016 at 6:43 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    When you said you put it back together "180 degrees out of phase" what exactly does that mean? Can you explain that a bit? Also, what was your final fix?
  6. Dec 12, 2016 at 6:59 AM
    PottMatter
    PottMatter Well-Known Member
    CoLoRfUl CoLoRaDo
    2012 Red Baja Taco
    https://youtu.be/5aCK4Bob6a0
    This was posted in another thread and I thought it answered the question pretty good
  7. Dec 12, 2016 at 7:05 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Interesting. So if you DID end up getting it out of phase, how would you be able to determine that's the problem and how would you fix it?
  8. Dec 12, 2016 at 7:17 AM
    PottMatter
    CoLoRfUl CoLoRaDo
    2012 Red Baja Taco
    Process of elimination . ..if I had messed with the drive shaft and then had a vibration, that is where I would start...if he had not messed with the drive shafts the problem would not be there....
    As far as figuring out it was out of phase...common to put back together wrong if you àr not watching
  9. Dec 12, 2016 at 7:41 AM
    ItalynStylion
    Steven
    DFW, Tx.
    I guess that was the real question....if it WAS put back together improperly, how do you go about figuring out the PROPER way to put it back?
    timbobzimbob likes this.
  10. Dec 12, 2016 at 7:54 AM
    PottMatter
    CoLoRfUl CoLoRaDo
    2012 Red Baja Taco
    I would start by making sure all the joints were all oriented the same way and go from there...
  11. Dec 13, 2016 at 4:20 AM
    NewfoundlandTaco
    Yeah the 2 piece drive shaft is balanced together from the factory, I took them apart at the middle u joint and reinstalled the rear 180 degrees from where it should have been which made it be out of balance. I figured it out because all the grease nipples on a 4x4 should all point the same way.
    PottMatter likes this.
  12. Sep 14, 2023 at 4:54 AM
    TacomaWilly
    TacomaWilly Well-Known Member
    Hey, super old thread but taking a shot here, lol.
    I did the same thing recently; replaced my Carrier Bearing and U joint but now drive shift vibrates especially when braking. I have had a seized U joint before which caused brake shudder but my U joints seem good.
    What were your vibs like? Noticeable at higher speeds? Did you end up with any sort of vibs when braking? I can feel a pop/wobble when driving slowly dragging the brakes (stop & go traffic). Makes me think it's a phase problem. The yokes were lined up as good as I could get them with the spline. Maybe I just need to rotate the yoke 180. I am going to try tonight.
