Driveshaft pulley bolt nightmare
Discussion in '1st Gen. Tacomas (1995-2004)' started by metaquanta, Dec 14, 2019.
  1. Dec 14, 2019 at 8:47 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    This video shows the basic premise on a lug nut. The guy uses an air hammer chisel, which you can also use, but I would prolly opt for a chisel and hammer until I got a good 'bite" on the bolt. I would also chisel on the outer circumference of the crank bolt as you will get more leverage there. Once you have a small flat chiseled out on the bolt, you can use a hefty punch and lay into it.
    I hope this makes sense, and I hope it helps.
    https://www.youtube.com/embed/oLoXgeSXoK0
  2. Dec 14, 2019 at 9:53 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    If you want to go full on hardcore:
    https://tinyurl.com/ttgjj9t
  3. Dec 14, 2019 at 10:07 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I know Irwin makes a 19 MM Socket for damaged Bolts and Nuts That would be my First effort.
    I have never been a big fan of the starter method to much chance for interesting events
  4. Dec 14, 2019 at 4:18 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
  5. Dec 14, 2019 at 5:08 PM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    This method has worked well for me also.
    I would not use a torch on the bolt. If you overheat the harmonic balancer (pulley) the rubber sandwiched in the balancer maybe damaged. This can cause the balancer to fail spectacularly.
    Hobbs[QUOTED] likes this.
  6. Dec 14, 2019 at 8:04 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Small pipe wrench and cheater pipe. Don’t use some crappy mushed jaws junk. Get a 6” Rigid, use them all the time on damaged bolts
    Hobbs likes this.
  7. Dec 15, 2019 at 7:14 PM
    Hobbs
    Yep…
    Did we get our crank bolt off? :notsure:
  8. Dec 16, 2019 at 9:15 AM
    metaquanta
    metaquanta [OP] Well-Known Member
    2000 2.7L MT 4x4, 240k mi
    I ground it down to a 19. Hammered the socket all the way on. Bumped the starter and it came loose. I still can't believe it's supposed to be a 19. I had to grind quite a bit off to get the 19 socket on.
    cruxofthebisquit and CS_AR like this.
  9. Dec 16, 2019 at 9:19 AM
    metaquanta
    The result:
    Hobbs and CS_AR like this.
  10. Dec 16, 2019 at 9:23 AM
    Hobbs
    Yep…
    Very cool! I'm glad you got it.
    The 19mm socket didn't fit due to the damage and distortion.
    Good for you! :thumbsup:
  11. Dec 16, 2019 at 10:40 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Yeah that one corner in that shot is enough to make the fit difficult.
    I know you were grinding in a depression.
    Congrats. For some reason I have ran into lots of transmission drain bolts like this. Being upside down I guess.
  12. Dec 16, 2019 at 1:29 PM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    Good job getting it off. Just courious - has any one ever used valve grinding compound on the inside of the socket to make it grab better? I heard that using a little of it on a striping phillips screw head really helps the tip bite in.
    CS_AR likes this.
  13. Dec 16, 2019 at 1:40 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I've done that on the inside of a Harbor Freight crow's foot wrench to get a little more traction when the fit was less than perfect.
    cruiserguy likes this.
  14. Dec 16, 2019 at 3:10 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I did on screws years ago not in the last 20 years
    Better Screw drivers
    CS_AR likes this.
