Driveshaft question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Twyatt, Jul 16, 2017.
  1. Jul 16, 2017 at 3:50 PM
    Twyatt
    Twyatt [OP] New Member
    Replace just the bad ujoint or all at once? 205,000 miles.
  2. Jul 16, 2017 at 4:26 PM
    NM Lance
    NM Lance Well-Known Member
    U-joints, unless your slip yoke and double cardan are trashed.
    Edit: Misread you, thought you were asking if you should replace the whole shaft assembly. I would replace all the U-joint while you have the drive shaft out.
    wilcam47 and Braves95 like this.
  3. Jul 17, 2017 at 6:44 AM
    mhorton1911
    mhorton1911 Fightin' Texas Aggie Class of '19
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    Trail Gear front and rear bumper, 5100's all 4 corners, Eibachs, toytec AAL 1980 Ford pickup horn, and lots of battlescars :)
    Do em all right now and youll probably never have to worry about em again
    Braves95 likes this.
  4. Jul 17, 2017 at 6:47 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    unless the driveshaft is bent or scratched up really bad, just replace the ujoints.
  5. Jul 17, 2017 at 3:05 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Hard to say Since you really don`t describe the problem other then a Bad U-Joint .
    If it is only one replace it
    I don`t touch these Joints to much of a pain to do myself.
