Driveshaft question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Budza, Jun 9, 2024.
  1. Jun 9, 2024 at 4:39 PM
    Budza
    Budza [OP] Member
    Terry
    Amarillo Tx.
    2015 Tacoma TRD SR6 and 2023 SR-TSS Off Road
    I have a 2023 Tacoma short bed. I am in the process of setting it up for towing behind a motorhome. I have installed the tow baseplate,breakaway switch and a power supply for the Brake Buddy. I am going to order a driveline disconnect from Superior driveline tomorrow. My question is about the drive shaft. Superior will send me a rear section of driveshaft with the disconnect installed on it. Does my NOW driveshaft just pull out of where the carrier bearing is or do I need to remove the entire driveshaft to replace the back shaft with the new one?Thanks for all help.
  2. Jun 9, 2024 at 5:22 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Unbolt the driveshaft from the differential pinion flange studs and the rear portion just pulls out of the slip yoke.
    The driveshaft is balanced at the factory as a complete assembly with the three U-joints and carrier bearing. Replacing just the rear portion may lead to vibrations at highway speeds, in which case you'd need to take the complete assembly to a local driveline shop to get re-balanced.
    RelentlessFab likes this.
  3. Jun 9, 2024 at 5:39 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Superior provides the rear driveshaft that includes the slip-joint.. it'll come with a u-joint (cross) on each end. You'll connect it to the yoke at the rear of the forward driveshaft then re-use the yoke/flange in the rear.
    soundman98 likes this.
  4. Jun 9, 2024 at 6:18 PM
    Budza
    Budza [OP] Member
    Terry
    Amarillo Tx.
    Thanks a lot fellas, just what I wanted to hear.....except the balancing part.. I will cross that bridge if it pops up!!!!!
  5. Jun 9, 2024 at 7:06 PM
    Gen3TacomaOBX
    S
    You're welcome. You didn't mention a brake light solution. I'd recommend the Roadmaster Led bulb/socket kit as it remains completely separate from the Tacoma's oem wiring.
  6. Jun 9, 2024 at 10:35 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Or, just tow the Motorhome with the Tacoma... (haha)
    Or..... buy a piece of junk to tow behind the Motorhome.
    Or..... just take the truck.
    Or..... Strap on a scooter to the back of the Motorhome.
  7. Jun 10, 2024 at 6:14 AM
    Budza
    Budza [OP] Member
    Terry
    Amarillo Tx.
  8. Jun 10, 2024 at 6:19 AM
    Budza
    Budza [OP] Member
    Terry
    Amarillo Tx.
    I installed a set of set of tail,brake, running lights between the tailgate and bumper and ran a 4 wire back them. These light strips are about 15 inches long and are LED, pretty bright.I connect this when towing. They are completely separate from the Tacoma system.Thanks again!!
    Gen3TacomaOBX and 3JOH22A like this.
