Driveshaft rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by NOLA ItsNotOva, Jul 19, 2013.
  1. Jul 19, 2013 at 7:59 AM
    NOLA ItsNotOva
    NOLA ItsNotOva [OP] Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I went to Cottmann Transmission the other day for a free diagnostic. I notice my truck is jerky when pulling off, shifting to reverse or drive, and when coming to a stop. Just recently I heard a noise from it. They said it was jammed or something like that and that they would have to rebuild it. Since I am starting out in college, money is kind of tight for me right now. They gave me an estimate of $1350 plus tax. I wanna ask you guys do you think that be the problem, or can it easily be solved without a rebuild?
  2. Jul 19, 2013 at 12:25 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    what? What specifically needs to be "rebuilt"?
    The u joints might be toast. (easy change)
    The tranny fluid could use a change...
    And if its Clunking at start/stop, it sounds like axle wrap. (add a leaf will stop that crap)
    The other thing might be the carrier bearing...
    Either way, fuck paying 1400 for for a "rebuild" when you could toss the current shaft, buy a Tom woods 1 piece, and eliminate any slight wobble you might of had before. A new precision balanced 1 piece drive shaft, with new mounting plates and tom woods gold sealed u joints, would run you about 450, before shipping... Best part, a 1 piece is lighter, stronger, doesnt need a carrier bearing, will have zero wobble, and will require slightly less RPM's to get up to speed (less rotational mass for the engine to turn)
  3. Jul 19, 2013 at 12:31 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Well he said that the drive shaft was jammed or something like that.
  4. Jul 19, 2013 at 12:31 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    He also said I needed rear trans mounts as well
  5. Jul 20, 2013 at 11:35 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    If he did indeed say that the drive shaft was "jammed", then he was BSing you. I've been doing my own maintenance on my own cars, motorcycles, and trucks for the last 50+ years and I never heard of a "jammed" drive shaft.
    I would first look at the rear trans mount, then both U-joints.
    Oh, and I would take my business elsewhere.
  6. Jul 20, 2013 at 11:44 AM
    yummjake
    yummjake Well-Known Member
    Jacob
    Richmond, VA
    00' EXT Tacoma 4wd
    5100's, Toytec coils, all-pro standard 3" lift leaf springs.
    OP, i realize your in New Orleans, and I'm up in Virginia, but my experience with Cottman's was horrible, would not recommend. I'd suggest taking your business elsewhere personally. Again, COMPLETELY different shops, but it sounds like they are trying to screw you over...
  7. Jul 20, 2013 at 11:53 AM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Well I don't know of anywhere down here that won't rip me off.
  8. Jul 20, 2013 at 4:46 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    Go to the thread below and ask for help or if anyone knows a reputable shop. It is the Louisiana thread. A lot of great folks in that thread. I'm in North Louisiana and don't know any shops down there.
    Louisiana
