Driveshaft removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ortacoma10, Sep 5, 2024.
  1. Sep 5, 2024 at 4:03 PM
    Ortacoma10
    Ortacoma10 [OP] Well-Known Member
    2010 Tacoma Trd Off-road 4x4
    There a certain extension for impact to remove 14mm bolts for driveshaft (going into transfer case) - couple I can’t reach with crescent wrench. or just recommended to lifting rear axle and spin it freely? Tia
    SethM likes this.
  2. Sep 5, 2024 at 5:36 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Please don't use a crescent wrench. It just rounds off the nuts/bolt heads.
    If you need to jack up the rear and use jack stands so you can rotate the shaft. Make sure you chock the front wheels so it doesnt run over you.
    SethM and Dm93 like this.
