Driveshaft Spacer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 650H1, Oct 4, 2011.
  1. Oct 4, 2011 at 7:53 AM
    650H1
    650H1 [OP] Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    anyone ever seen a driveshaft spacer for sale? its basically a spacer that goes between the two flanges on the rear driveshaft to push the slip yoke back together so it gets rid of driveline vibes. i know you can have a shaft lengthened for like 200 bucks but the spacers would be like 60 and work just as well. anyone know where i could get one? or can anyone make me one? i dont know the bolt patter on our driveshaft flanges, is it 65mm x 65mm? any info would be great, and i think this could be a solution to alot of our driveshaft noise/vibe problems for cheap money.
  2. Oct 4, 2011 at 8:36 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    ....Or..... Install double cardan shaft
  3. Oct 4, 2011 at 8:37 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    the carrier bearing drop?
    go to ace hardware and buy some top notch grade 8 washers and bolts.
  4. Oct 4, 2011 at 10:50 AM
    650H1
    Michael
    VA
    no not the carrier bearing drop, and the double kardan shaft is like 500 bucks. what im saying is if there is a driveshaft spacer i.e. a 1" thick piece of aluminum or steel block with 4 holes in it (that are the bolt pattern of our driveshaft flange bolt holes) that would literally act as a spacer for the driveshaft to push the slip yoke back together = less wear on the slip, and no more vibes or noise. you guys see what im saying?
    here is a link to a site with the spacers im talking about, im just not sure if any of these will fit out 2nd gen trucks.
    http://www.4crawler.com/4x4/ForSale/DriveshaftSpacer.shtml
  5. Oct 4, 2011 at 10:51 AM
    6L PSD
    6L PSD Well-Known Member
    North Pole, AK
    '11 4x4 DCSB OR TXP
    Fogs anytime, locker anytime, Moose lights (Lightforce), Randy Ellis Design light bar
  6. Oct 4, 2011 at 10:56 AM
    650H1
    Michael
    VA
  7. Oct 4, 2011 at 10:58 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :popcorn: subbed for info...
  8. Oct 4, 2011 at 12:38 PM
    BlueT
    NorthEast
    I think 4runner ds is the same lengths as your RC ds, used one is probably under $100 on junkyard. Toyota had cheap out on trucks and now only installs single u-joint. Used tobe DC to prevent vibes especially with raised truck
  9. Oct 4, 2011 at 1:42 PM
    6L PSD
    North Pole, AK
    '11 4x4 DCSB OR TXP
    I'm not sure on the pattern...probably best to call. Super nice folks to deal with. They may be able to make you one for the Tacoma if the stock listed ones won't work??? It still may be cheaper to buy multi-pattern flanges from someone like Marlin Crawler than to have a driveshaft customized...I know that to be true in my neck of the woods anyhow!!?
  10. Oct 10, 2011 at 6:18 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I've been trying to think of ways to fix this problem too, without buying a whole new driveshaft. I don't understand how spacers would help anything unless the spindles of the slip yoke are tapered towards the ends. Is that true? I've never had it apart before.
    Maybe there's some sort of grease that would work to fill in the annular space around the spindles? It would have to be something that doesn't break down easily.
  11. Oct 10, 2011 at 6:41 AM
    650H1
    Michael
    VA
    youre not getting it. this spacer would be probably an inch thick, would mount BETWEEN the end of the rear d-shaft, and the rear diff flange. it would be like lengthening your driveshaft without paying a lot of money to have a shoop cut it and add a piece to it - so it WOULD work and WOULD make a difference as it would put the slip yoke back together so we dont get any vibes or noise from it.
  12. Oct 10, 2011 at 7:08 AM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    sub'd Will the one on longfieldsuperaxles.com fit a 2nd gen?
  13. Sep 28, 2013 at 2:53 AM
    MAUIxROCKSTAR
    MAUIxROCKSTAR Well-Known Member
    Maui, Hawaii
    2015 VOODOO BLUE TACOMA
    does anyone know the spacing between the bolts on the pinon flange for a spacer?
