Driveshaft stud ??
Discussion in '1st Gen. Tacomas (1995-2004)' started by anthony250f, Sep 6, 2015.
  1. Sep 6, 2015 at 9:14 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I stripped a driveshaft stud bolt, can this be replaced with a bolt ?
  2. Sep 6, 2015 at 9:33 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    no idea where you're talking about. got a pic or more details?
  3. Sep 6, 2015 at 9:44 PM
    anthony250f
    Anthony
    San Diego, CA
  4. Sep 6, 2015 at 10:13 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    yes just garb it with a big locking vise grip pliers or cut it off and then replace it with a new bolt from the dealer or buy a grade #8 bolt, DO NOT just put a generic bolt in it or it will snap off under the stress, it needs to be a hardened grade #8 or higher bolt for it to have the proper strength
  5. Sep 6, 2015 at 10:53 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Part numbers should be:
    Propellor Flange Nut: Toyota 90080-17239
    Propellor Flange Washers (pack of 4): Toyota 90560-10H00
    Propellor Flange Bolt: Toyota 90080-10294
    Might want to double check but pretty sure. That's what I used last time I ordered from Camelback.
  6. Sep 6, 2015 at 11:19 PM
    anthony250f
    Anthony
    San Diego, CA
    Were those the press in style bolts ??
  7. Sep 7, 2015 at 1:08 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Get the correct parts from the dealer!!!
    A regular bolt no matter what grade will come loose!!
    The fit where it goes through the flange is critical !!!
  8. Sep 7, 2015 at 6:59 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    bolt should be "splined" also where it goes through the flange,,, I wouldn't chance it.
  9. Sep 7, 2015 at 7:31 AM
    anthony250f
    Anthony
    San Diego, CA
    Ok I've been looking and can't find this part...looks like I have to buy the entire flange
  10. Sep 7, 2015 at 7:47 AM
    tomtom
    The Desert SW
    2012 FJ
    The press-in-bolt is not available from the dealer. You have to buy the whole flange if you want to replace one. I went looking when the garage that did the clutch left me a few surprises.
    I've been running the regular non-press bolts for awhile now with no issue. Same bolts that get used at all the other flanges. Just made sure to torque them to spec and haven't loosened since.
    One of these days, I'll get around to replacing it but since every other flange uses non-pressed bolts, figured it was good enough.
    Crom and anthony250f[OP] like this.
  11. Sep 7, 2015 at 7:50 AM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
  12. Sep 7, 2015 at 7:51 AM
    tomtom
    The Desert SW
    2012 FJ
    Yup, those be the non-splined toyota ones. I wonder if they are offering them for cheaper than the dealer.
  13. Sep 7, 2015 at 8:22 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The Toyota Drive Flange bolts will work !!
    Using bolts makes it easier to get the drive shaft out as well
    It is off the shelf bolts that cause problems .
    anthony250f[OP] likes this.
  14. Sep 7, 2015 at 9:19 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    This is interesting. I've never seen a pressed-in bolt on a Toyota flange. Anyone know what models and which flanges came like that from the factory? The flange on the rear diff of my Tacoma doesn't have any. My '84 4runner didn't have any at all, front or rear.
  15. Sep 7, 2015 at 9:20 AM
    tomtom
    The Desert SW
    2012 FJ
    On my 2003, they are only on the transfer case output flanges.
  16. Sep 7, 2015 at 9:58 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    ^^ Same for my 2003. The bolts are pressed in. The splines look similar to a wheel stud.
    The shoulder length is close to the thickness of the DS flange and is an exact fit for the hole in said flange. No slop at all.
    Hope this helps you.
  17. Sep 7, 2015 at 10:05 AM
    tan4x4
    Rick
    Folsom, CA
    All 4 are the pressed-in type, or just one of them?
  18. Sep 7, 2015 at 10:09 AM
    anthony250f
    Anthony
    San Diego, CA
    All 4 are press in for the rear driveshaft, and they are pressed in off the t case too for the front d shaft
    Can I use grade 8 bolts is the shoulder is the proper length? It's strange...the press in bolts for the front d shaft are smaller ...about a m10....the ones for the rear driveshaft are about a m12 , but seem like a m11
  19. Sep 7, 2015 at 10:09 AM
    anthony250f
    Anthony
    San Diego, CA
    I will not replace the entire flange, too much cost sir something so stupid
  20. Sep 7, 2015 at 12:02 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    That is why I got the bolts at the dealer They were like 11mm a strange size for sure .
