Driveshaft TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thomas Jefferson, Oct 17, 2015.
  1. Oct 17, 2015 at 2:15 PM
    Thomas Jefferson
    Thomas Jefferson [OP] Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Howdy all,
    For about two weeks now my truck has had a large clunking noise coming from the rear under braking and sometimes when I released the brakes. I assumed it was a self adjusting spring in the rear drums or possibly a bushing was out of whack. It didn't seem to hamper performance but it was annoying. Anyways I have 34K on the clock so I got it into the dealer before 36K just in case it was under warranty. Just got a call from my service advisor saying that the mechanic was able to replicate the issue and that there's a TSB Recall on the driveshaft. Even the advisor was pretty surprised and thought it may be brake shoe movement when I dropped it off. So lucky me gets a brand new driveshaft for free. If anyone else has a clicking/ clunking noise coming from the rear while braking take it in. Also I have a 2013 Double Cab SR5 4x4 Auto.
  2. Oct 17, 2015 at 2:17 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do you by chance have the TSB number?
  3. Oct 17, 2015 at 2:18 PM
    Thomas Jefferson
    Sacramento,CA
    '13 SR5 DCSB 4x4
    I will be picking my truck up later today and I can post it when I get it. They didn't have the part in stock so I'm gonna bring it back in next week to get the repair done. They also said it's safe to drive on the faulty part.
  4. Oct 17, 2015 at 2:23 PM
    nd4spdbh
    SoCal
    its not a faulty part, just simply a dried up slip joint, quite common.
    but definietly get the TSB printed out from them.
  5. Oct 17, 2015 at 3:49 PM
    Stroonzo
    Stroonzo Well-Known Member
    It wasn't the carrier bearing?
  6. Oct 17, 2015 at 6:43 PM
    nd4spdbh
    SoCal
    the clunk when stopped is due to axle wrap, on the prerunners the clunk comes from the slip yoke at the transmission, on 4x4's it comes from the slip joint just after the center u joint in the rearward section of the driveshaft.
  7. Oct 27, 2015 at 3:01 PM
    Thomas Jefferson
    Sacramento,CA
    '13 SR5 DCSB 4x4
    Its TSB 0016-13
  8. Oct 27, 2015 at 6:47 PM
    ClemsonMGM
    ClemsonMGM Even Firemen Need Heroes...
    Workin the pole!
    12 Ram 2500
    Could this be a problem since new? Mine has done it from day 1...
  9. Oct 27, 2015 at 6:48 PM
    ClemsonMGM
    Workin the pole!
    12 Ram 2500
    And op did the tsb fix the problem???
  10. Oct 27, 2015 at 8:32 PM
    Thomas Jefferson
    Sacramento,CA
    '13 SR5 DCSB 4x4
    The tsb fixed the problem it runs great now.
  11. Oct 31, 2015 at 8:02 AM
    ClemsonMGM
    Workin the pole!
    12 Ram 2500
    Just leaving the dealership . New driveshaft will be here Tuesday!
  12. Oct 31, 2015 at 9:12 AM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Besides the clunk during braking, did you hear any chatter noise coming from underneath the truck while driving, radio off? I ask because I recently have that condition. I then greased my drive shaft,all zerk fittings, and the chatter greatly reduced, if not went a way. Wonder what I have going on down there? 13' with only 36k on the clock.
  13. Oct 31, 2015 at 11:20 AM
    ClemsonMGM
    Workin the pole!
    12 Ram 2500
    The only complaint I had was the clunk when accelerating from a stop or coming to a stop. No other noises.
