driveshaft vibes shims or carrier drop???
Discussion in 'Suspension' started by myfirst06taco, Oct 11, 2011.
  1. Oct 11, 2011 at 4:55 PM
    myfirst06taco
    myfirst06taco [OP] Well-Known Member
    Clarke county ,VA
    06 SR5 4X4
    5100's eibach coils , Allpro leaf pack , roll up tonneau cover with led bed lights, hids, homertaco grill
    What works better for vibes ? I just lifted my 06 dclb and have some vibe @ 20-30mph. the shims cost more and take longer to install ,when the ome carrier drop is cheaper and looks like a 10min job. Any opinions would be great thanks.
  2. Oct 12, 2011 at 11:34 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    You are correct, so far. Try the drop first, try the shims second, try both third.
  3. Oct 13, 2011 at 11:54 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    Strange, with my first lift I had no vibe issues, then when I put on my new coils I had vibes right off take off, then when i finally cranked my coils up my coils dissapeared and the truck drives perfectly straight with no wobbles or vibes or anything. Good luck.
  4. Oct 13, 2011 at 2:20 PM
    myfirst06taco
    Clarke county ,VA
    06 SR5 4X4
    the vibrations only came after I lifted the rear , i guess i will try the shims first. thanks
  5. Oct 13, 2011 at 2:24 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    no try the carrier bearing drop 1st. look up beefed taco under vendors and he sells a carrier bearing drop with a very reasonable price. his website is also streettacos.com i think
  6. Nov 12, 2011 at 11:43 PM
    HarryTaco
    HarryTaco Well-Known Member
    Pacific NW
    2016 TRD OR DCSB 4x4 V6 MGM
    Bed Mat, Bak Revolver Tonneau,
    streetacos.com
