Driveshaft vibration 2019 tacoma sr
Discussion in '3rd Gen. Tacomas (2016-2023)' started by codybishop8677, Aug 6, 2020.
  1. Aug 6, 2020 at 12:32 AM
    codybishop8677
    codybishop8677 [OP] Member
    Cody
    2019 Tacoma Double Cab Sr 4x4
    3 inch lift, front: OME coils rear OME dakar medium duty leaf pack. Bilstein 5100 shocks, 285/70/17 Nitto Ridge Grappler with Fuel Tactic 17 inch wheels
    I know there are threads but I'm wanting some exact help please. I have a 2019 tacoma with a 3 inch lift. I've been chasing mild vibration for a while. Yes I have the EGGS bushing already. The last time I took it in the shop looked at it and took out my rear driveshaft and said no vibration they added a 2.5 degree shim and it helped but I still have some deceleration vibes T around 25 mph and 10 to 12 mph? What next? 1 piece driveshaft?
  2. Aug 6, 2020 at 12:48 AM
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    How are your tires wearing? And what kind of tires?
  3. Aug 6, 2020 at 12:49 AM
    codybishop8677
    Cody
    They are pretty much new but wearing evenly
  4. Aug 6, 2020 at 12:54 AM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Have you had them rebalanced since this all started?
    There’s a bunch of things that can cause a vibration.
    What exactly do you mean this vibration happens on deceleration? Like when your pressing in the brakes it starts to vibrate?
    most of the when I have seen a drive line vibration it’s in movement between speeds, whether accelerating/slowing/coasting it’s there
  5. Aug 6, 2020 at 12:56 AM
    codybishop8677
    Cody
    Yes when I am breaking coming to a slow stop there is a mild vibration from like 25 mph down to 20. It's not there on acceleration though
  6. Aug 6, 2020 at 12:57 AM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    If it’s not there when your foot is on the gas or when your coasting check your brakes
  7. Aug 6, 2020 at 1:10 AM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Can also try to bump it to 3* shims, but it’s really weird that it’s not happening under load.
  8. Aug 6, 2020 at 1:12 AM
    codybishop8677
    Cody
    Alright thanks. Its been aggravating to try to fix.
  9. Aug 6, 2020 at 1:35 AM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    It’s just the life of the beast when you lift a truck. Just gotta go through and test stuff till you figure out the cause and then move to the fix.
  10. Aug 6, 2020 at 5:01 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Try test driving a stock truck off the lot before you throw anymore time or money at this- decel shudder around those speeds is common, mine has a slight, but repeatable, and the others ones I've driven had the same.
